- Thread starter
- #201
mavisky
DSM Wiseman
- 5,387
- 43
- Sep 13, 2002
Atlanta,
Georgia
yes they'll work just fine.
Note: This feature currently requires accessing the site using the built-in Safari browser.
mkspriggs said:can we use are non turbo accesorys without any problems?like altenator,power steering and so on
Raph said:mine ran fine yesterday..but today it felt slow??? like hitting fuel cut.. or the ecu was pulling timing..i think i may be getting toio little fuel or something..
\im only running 7psi on 310cc and a fuelpressure riser
oh and the dog stole and burried my oil filler cap ! (had to take one off another car )
it was in the garage,the dog was there sniffing around..then he ran off..i thought nothing of it.. then the oilcap was gone! i searched everywhere
i maty need 370ccs and a fuelpump(walbro 190?) what yall think?
btw its a 4g63 nt plus a turbo rigged on it..i have a stock intercooler,2g bov .
Raph said:update! found the oilcap(dog hid it in his kennel)
tbTalonES94 said:If he get's the walbro 255 then he might have to get an adjustbale fuel pressure regulator because the pump will over-run the stock FPR. The 190 would more then likely not do this.
no it will not over-run his stock fpr. im running a walbro 255 right now with no turbo and my car runs as stong as ever. the fpr will do exactly what its suppose to do, regulate the fuel pressure.
the tranny i have fits the 225mm flywheel found in the 2g gstd.. i havent had problems yetTimG said:About the n/t trannies. What more proof do you need?http://www.dsmtuners.com/forums/showthread.php?p=1562073#post1562073
Project ES said:I was told before that you could buy high impedance injectors but they are harder to come by for some reason. I did the siring in of my injector resistor pack and its not hard at all. Only 5 wires if im not mistaken. Good luck
