1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
GVR-4 IAC Valve removal problem
Posted by 914 Cheeko, Aug 8, 2018
Please Support Ace Race Parts
  1. 914 Cheeko
    914 Cheeko Probationary Member
    23
    Joined Jul 10, 2018
    Newtown, Connecticut
    So i was removing my sh**ty IAC valve that came with the engine from DSM and when i tried slowly pulling it out the whole thing split apart into 3 sections (so far.) The first pic is how it came out once I unscrewed it. The second is what was stuck at first, but slid off. Now I'm stuck with the valve itself stuck in the port (third picture.) 20180808_153911.jpg 20180808_153927.jpg 20180808_153948.jpg How do I get this out? I'm afraid if i try pulling it out any harder than I tried it's going to break a piece off into my engine. WD40?
    Log in/Register to remove ads
    My DSM:
    1991 Mitsubishi Galant VR-4
    Street Build
      manual
    Loading...
    Featured Products from our Supporting Vendors
  2. rEclipserGST
    rEclipserGST Proven Member
    1,395
    14
    Joined Nov 17, 2007
    G-City, Ohio
    You just split it in half. The two (2) phillips/10mm bolt is what holds the IAC on.
    My DSM:
    1995 Eagle Talon TSi AWD
    Street Build
    187 whp   200 lb/ft
    1995 Eagle Talon TSi AWD (sold)
    13.583 @ 108.440 MPH
    Loading...
    Dsm panda and DSMFryGuy like this.
  3. DSMFryGuy
    DSMFryGuy Probationary Member
    9
    Joined Apr 25, 2018
    Berlin, Wisconsin
    what he said ^^
    My DSM:
    1992 Mitsubishi Eclipse GSX
    Street Build
    16g   manual
    Loading...
  4. 914 Cheeko
    23
    Joined Jul 10, 2018
    So am I f***ed or how would I get it out?
    My DSM:
    Street Build
      manual
    Loading...
  5. Boomdeeze
    Boomdeeze Proven Member
    1,450
    176
    Joined Jul 5, 2009
    Independence, Minnesota
    You take out the two 10mm bolt on each side and pull the sensor out.. The three screws you took out are what hold the two pieces of the sensor together. You can see one of the 10mm bolts in the last picture you posted.
    My DSM:
    1997 Mitsubishi Eclipse GSX
    Street Build
    10.793 @ 128.98 MPH
    Loading...
  6. tametalon92
    tametalon92 Proven Member
    1,438
    278
    Joined Jan 5, 2012
    Rathdrum, Idaho
    I'm sorry. Nothing to contribute. But I giggled at this a bit...:oops:
    My DSM:
    1992 Eagle Talon TSi AWD
    Street Build
      manual
    Street Build
    14b   manual
    Loading...
    spyderdrifter and shinzon like this.
  7. chrysler kid
    chrysler kid Proven Member
    1,552
    366
    Joined Dec 20, 2002
    Mckinney, Texas
    You're screwed (you unbolted the wrong bolts you twaat) . There are still 2 more bolts behind the half of the sensor you removed
    Remove those two screws so the hole looks like this
    Loading...
    rEclipserGST and tametalon92 like this.
  8. 914 Cheeko
    23
    Joined Jul 10, 2018
    Well f*** me in the ass I got the wrong IAC too.
    My DSM:
    Street Build
      manual
    Loading...
  9. Dsm panda
    Dsm panda Proven Member
    142
    29
    Joined Dec 8, 2017
    Franklin, Wisconsin
    Dis you get the 90s one? Or is it black not brown?
    My DSM:
    1991 Eagle Talon TSi
    327 whp   307 lb/ft
    1990 Plymouth Laser RS Turbo
    Street Build
      manual
    Loading...
  10. chrysler kid
    1,552
    366
    Joined Dec 20, 2002
    Mckinney, Texas
    Just save yourself time and stress and remove the throttle body to replace the iac
    Loading...
  11. Jamesberry2382
    Jamesberry2382 Probationary Member
    8
    3
    Joined Jul 21, 2018
    Griffith, Indiana
    Agreed it's easier if you pull the throttle body
    My DSM:
    Loading...
  12. steve
    steve DSM Wiseman
    12,574
    427
    Joined Feb 3, 2002
    St. Charles, Illinois
    How so? There are three, the 90 style, the original metal 91+, and the new plastic 91+ version. The 91+ plastic version is the preferred version if you have a 91+ ISC/IAC since it's less likely to short out and damage your ECU.
    My DSM:
    Loading...
    1990TSIAWDTALON likes this.
  13. Dsm panda
    142
    29
    Joined Dec 8, 2017
    Franklin, Wisconsin
    Not to mention I made the revised plastic one fit my 90 and if you bought from a parts store that's the one you get?
    My DSM:
    327 whp   307 lb/ft
    Street Build
      manual
    Loading...
  14. 914 Cheeko
    23
    Joined Jul 10, 2018
    It came with the brown one which I heard are constantly defective. I bought a black one, now I just need to get the stripped screws out.
    My DSM:
    Street Build
      manual
    Loading...
  15. 914 Cheeko
    23
    Joined Jul 10, 2018
    Yeah it had the brown one. I am installing a newer black one hoping that fixes my stalling issue.
    My DSM:
    Street Build
      manual
    Loading...
  16. 914 Cheeko
    23
    Joined Jul 10, 2018
    I bought it on Ebay but it said it would fit. I have no idea why they sent me only half of it.
    My DSM:
    Street Build
      manual
    Loading...
  17. rEclipserGST
    1,395
    14
    Joined Nov 17, 2007
    G-City, Ohio
    Post a picture of this part you speak of.
    Did you use a screw driver or an 8mm socket?
    My DSM:
    Street Build
    187 whp   200 lb/ft
    Loading...
  18. 914 Cheeko
    23
    Joined Jul 10, 2018
    It was the front/top of it without the part that attaches to the manifold. I was able to get the part off that this replaces but I couldn't get the rest of it off where the valve was, so it wouldn't fit. I used a screw driver because it had the rounded edges, it won't fit a socket. The full part does though. The full part has 2 bolts, this one has 3.
    My DSM:
    Street Build
      manual
    Loading...
  19. pauleyman
    pauleyman DSM Wiseman
    4,748
    812
    Joined Nov 19, 2011
    oklahoma city, Oklahoma
    You may just want to start over. Get a complete new isc and install.
    My DSM:
    1997 Eagle Talon TSi AWD
    Street Build
    T25   manual
    Loading...
  20. We're on Boost
    We're on Boost Proven Member
    824
    43
    Joined Aug 25, 2007
    Seattle area, Washington
    What's up with the 3 bolt flange on the one you are showing? That looks like the one used by the Evo 8, which has a 3 bolt flange.
    I know like nothing about GVR-4, but Rock Auto shows the familiar 2 bolt flange ISC/IAC for the 1991 GVR-4.
    Rock Auto has good pics what it should look like. Usually their prices are good too, but I see the price on this item has doubled since I bought mine about a year ago!!
    Anyway, here, the IAC section for your car:
    https://www.rockauto.com/en/catalog...,fuel+&+air,idle+air+control+(iac)+valve,6072
    and here, the "info" for the Airtex/Wells. That picture, you can scroll through it, there are 5 pics there.
    https://www.rockauto.com/en/moreinfo.php?pk=944131&cc=1103050&jsn=10
    My DSM:
    1990 Eagle Talon TSi AWD
    650 whp   510 lb/ft
    Loading...
    Vegas smith likes this.
  21. We're on Boost
    824
    43
    Joined Aug 25, 2007
    But for the 1991 Talon, they still list the Standard Motor Products "AC146" for less than the price a year ago.
    This is what I expected to see for your car. I don't know why they don't show it there. But this is what I have in my car, the Standard Motor Products AC146. It seems fine. I just had to swap some wires around because mine is a 1990.
    My DSM:
    650 whp   510 lb/ft
    Loading...
  22. 914 Cheeko
    23
    Joined Jul 10, 2018
    The 3 bolt one is only half of the IAC for the 2g 4G63T I have. The other half that connects to the intake manifold that holdes the actual valve in place has 2 bolts. It doesn't have the stock GVR4 engine, it has a swapped Eclipse GSX 4G63T.
    My DSM:
    Street Build
      manual
    Loading...
  23. We're on Boost
    824
    43
    Joined Aug 25, 2007
    The part of it that was stuck, did you ever get that out?
    My DSM:
    650 whp   510 lb/ft
    Loading...
  24. steve
    steve DSM Wiseman
    12,574
    427
    Joined Feb 3, 2002
    You have me scratching my head wondering exactly what you need help with at this point?
    My DSM:
    Loading...
  25. 914 Cheeko
    23
    Joined Jul 10, 2018
    I don't need help anymore all I need to do at this point is get these rusted and stripped screws off
    My DSM:
    Street Build
      manual
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
