1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
How to Identify an EPROM ECU
Posted by snowborder714, May 28, 2009
Please Support ExtremePSI
  1. snowborder714
    snowborder714 Moderator
    11,924
    205
    Joined Oct 15, 2006
    Mechanicsburg, Pennsylvania
    Here are many links you can use to aid in identifying an EPROM ECU. DO NOT always go by what the sticker says on the case, as it may have been swapped.
    epromid [ECMTuning - wiki]
    Eclipse Talon Laser Galant 3000GT Stealth ECU ID Reference
    http://www.dsmtuners.com/forums/tuning-engine-management/329315-eprom-check.html
    95-96 EPROM Check
    http://www.dsmtuners.com/forums/tun...4945-how-identify-eprom-ecu-merged-5-9-a.html
    Once you've identified that you do have an EPROM, you need to check if it has been socketed. The "Socket Check" section on this page will help you do that. This is so you can run an aftermarket EPROM chip (i.e. for ECMlink).
    If it is not socketed, you will need to get in touch with ECMTuning to arrange for them to socket your ECU. Or if you are comfortable working on electrical boards like this, you can attempt it yourself. Here's the page with the correct socket info.
    Log in/Register to remove ads
    My DSM:
    1995 Mitsubishi Eclipse GST
    12.529 @ 110.820 MPH
    Loading...
    Featured Products from our Supporting Vendors
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
