Jgw272
- 0
- Jul 29, 2018
Gloucester,
Europe
Note: This feature currently requires accessing the site using the built-in Safari browser.
Thanks for the tip. im new to this site so trying to work my way aroundMight be better to post this in the turbo identification thread. Looks like maybe an h1c?
@amsrn13 nice work on the setup!
It’s deffinetaly a v band mounting, Although I’m unaware of how to accurately measure the inducer and exducer. Also what is the sticky s? Sorry to be so unfamiliar with this but it’s my first time looking into things.There's so many variants to holset turbos. That's going to be tough. First see if its held on by bolts or a v band. If its bolted it's an hx 35 then you're going to need to measure the inducer inlet to get an accurate idea what wheel went in. There were a lot of different wheels used I've got a goofy one with 48mm inducer and 83 exducer to give you an idea. Check out the sticky s that are up in the turbo system tech for holsets
They are the first threads that appear on the top of the turbo system tech sub forumIt’s deffinetaly a v band mounting, Although I’m unaware of how to accurately measure the inducer and exducer. Also what is the sticky s? Sorry to be so unfamiliar with this but it’s my first time looking into things.
