1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
GVR4 hx35 max Rpm ?
Posted by cptncreme, Oct 11, 2018
Please Support Boostin Performance
  1. cptncreme
    cptncreme Probationary Member
    24
    6
    Joined Feb 10, 2017
    Austin, Texas
    So I have a built 2.0 with full e85 fuel system on v3 SD. I am running fp manifold, 7 blade hx35 with bep .55 housing, 272 cams, stock intake, 2.5" intercooler piping. It's running great just thought it would pull higher up top.ax boost about 4000 Rpm, 32 psi, but power falls off pretty hard at about 6700, boost is steady though, just like it runs out of air because fuel goes rich...is this because the 55 housing??
    Log in/Register to remove ads
    Featured Products from our Supporting Vendors
  2. Vegas smith
    Vegas smith Proven Member
    2,114
    920
    Joined Dec 2, 2002
    Houston, Texas
    It surely isn't helping.
    My DSM:
    1993 Eagle Talon TSi AWD
    Street Build
    GT30   manual
    1992 Eagle Talon TSi AWD (sold)
    16g   manual
    Loading...
  3. Boomdeeze
    Boomdeeze Proven Member
    1,456
    176
    Joined Jul 5, 2009
    Independence, Minnesota
    Sounds like you have other contributing factors, I doubt the .55 housing is cutting airflow at 6700 rpms. Are you sure it's not in the tune where is starts to get rich? What A/F are you seeing?
    My DSM:
    1997 Mitsubishi Eclipse GSX
    Street Build
    10.793 @ 128.98 MPH
    Loading...
  4. cptncreme
    24
    6
    Joined Feb 10, 2017
    Austin, Texas
    Ya I leaned it out some up top in the rpm range. Before I leaned it out with the SD table it was dipping into high 10's with e85 and breaking up. Going to pull some more out and see if it pulls higher. I have already done blt a few times and nothing. Running an external mvs 38mm wg.
  5. 19gsx91
    19gsx91 Proven Member
    926
    257
    Joined Apr 20, 2011
    Walworth, New York
    What are you using to control boost? internally or externally gated? MBC or electronic boost controller?
    My DSM:
    1992 Mitsubishi Eclipse GSX
    Street Build
    292 whp   264 lb/ft
    Loading...
  6. Boomdeeze
    1,456
    176
    Joined Jul 5, 2009
    Can you post a log?
    My DSM:
    Street Build
    10.793 @ 128.98 MPH
    Loading...
  7. OH91awd
    OH91awd Proven Member
    291
    114
    Joined Sep 22, 2011
    chillicothe, Ohio
    the .55ar housing is a restriction on the holsets. although ive seen most people get in the 7000rpm range before power falls off. that small of a housing dont expect much more than that though.
    My DSM:
    Drag Race Build
    10.89 @ 125.67 MPH
    1991 Eagle Talon TSi AWD (sold)
    Street Build
    GT35   manual
    Loading...
  8. 19gsx91
    926
    257
    Joined Apr 20, 2011
    Walworth, New York
    I have a .55 housing on a 7 blade hx40 and boost climbs past 5k and I have to turn my duty cycles down the higher my RPM is to compensate. and that .55 housing is a choke point for my turbo, not so much on an hx35.
    I'd be willing to bet if he is internally gated and running an MBC that those two will cause issues with boost control.
    My DSM:
    Street Build
    292 whp   264 lb/ft
    Loading...
  9. OH91awd
    291
    114
    Joined Sep 22, 2011
    chillicothe, Ohio
    hes not internally gated though and hes not having boost control issues. power is falling off after 6700rpm. and yes the .55 chokes on a hx35.
    My DSM:
    Drag Race Build
    10.89 @ 125.67 MPH
    Street Build
    GT35   manual
    Loading...
    19gsx91 likes this.
  10. cptncreme
    24
    6
    Joined Feb 10, 2017
    Austin, Texas
    Ya I'm not having boost issues, it holds 31-32 psi all the way through the pull. External mvs gate and manual boost controller
    19gsx91 likes this.
  11. 19gsx91
    926
    257
    Joined Apr 20, 2011
    Walworth, New York
    "but power falls off pretty hard at about 6700, boost is steady though, just like it runs out of air because fuel goes rich...is this because the 55 housing??"
    Sorry, at work. Missed the boost being steady part and the external. That's odd then. I've had zero issues with my setup and between the two of us a 7 blade 40 should have a much more significant choke than a 35. I don't think that's to blame.
    My DSM:
    Street Build
    292 whp   264 lb/ft
    Loading...
  12. spyve4
    spyve4 Probationary Member
    21
    5
    Joined Apr 19, 2009
    St. Augustine, Florida
    Bov leak= rich condition?
    My DSM:
    Street Build
    20g   manual
    Loading...
  13. donniekak
    donniekak DSM Wiseman
    4,457
    727
    Joined Mar 23, 2008
    Surprise, Arizona
    The hx40 works better in the small housing because the turbine is so much bigger.
    The only bolt on housing I’ve used, (and I’ve used them all) that works like a similar size t3 or t4 housing is the fp30 hotside. Even the 8cm housings the red and black come in are a joke.
    My DSM:
    Street Build
      manual
    Loading...
    OH91awd likes this.
  14. cptncreme
    24
    6
    Joined Feb 10, 2017
    Austin, Texas
    I dunno about that, but not losing boost. Brand new real HKS ssq
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
