97egl
- 721
- 445
- Feb 6, 2014
Brownsburg,
Indiana
I've had nothing but bad luck with the only 2 machine shops I could find in Indianapolis. Schmidt Automotive ran a cutter over my cylinder head so fast that it couldn't seal to an MLS head gasket as well as messed up a block that was supposed to be decked .050 so bad that the pistons where proud .015 on one side and .010 below the deck on the other side. Then richards cylinder heads couldn't line bore a new cam cap in on a cylinder head and tried to tell me they pressure tested it and it failed when all I had asked for was the line bore to be done for a new cap. Someone had tried to line bore it and messed up so why they would pressure test it AFTER trying to do work on it is beyond me.
Anyways I am looking for a machine shop that does good work around here. I'm willing to drive an hour or so if I have to. I have to get another block decked .050 a cylinder head resurface, as well as a 6 bolt block bored from 85mm to 86mm for the new pistons I got and I cannot afford to have the 6 bolt block messed up.
Sorry if this is posted in the wrong area
