hazzard74
- 5
- Apr 9, 2017
Forest Grove,
Oregon
Hi everyone.
This started with a 93 Eclipse FWD, non-turbo, manual trans. I'm swapping my blown 7-bolt for a JDM 6-bolt. It has gone pretty smooth until I went to mount the trans. The flywheel that came with the 6-bolt is too big to fit in the bellhousing.
So, what flywheel do I have, and what flywheel do I need to get? Will I be able to use the old starter (which is actually only 2 months old)? And do I need to swap the tin plate that goes between the trans and the block?
On a side note: I got an Exedy Stage 0 clutch kit from JNZ that is supposed to fit all DSMs 90-99. The face of the 7-bolt flywheel is completely flush, and there is no way it would work with this clutch kit. Has this flywheel been modified?
I'm so confused, but I love these cars and I want to learn everything.
Thanks in advance.
If I can provide any further info/pics to help please let me know.
Thanks in advance.
