e_miller81
- 35
- 1
- Jun 1, 2006
Elkhart,
Indiana
I have building a 97 Eclipse GSX for the past 10 years. I have a fully built 7 bolt 4G63. I’m running a map sensor, Aem ems-4 stand-alone, Aem 4 channel twin fire ignition with Chrysler 300m cop setup. I have an aeromotive A1000 fuel pump with fuel pressure regulator with FIC 1650 injectors. I will be happy to provide more of specs of the car if needed.
I went to have the vehicle tuned and ended up having issues with the wiring of the fuel pump. I was losing voltage so I ended up not being able to get it tuned. Since then I figured away to fix the fuel pump voltage issue. I went to drive the car before I did that wiring work on the fuel pump and when I went to accelerate The car backfired or something and almost felt the car hop. It happend so quick. The car continued to run but had no throttle response.
First thing I checked was throttle cable and body. No issue everything is moving free. The car will not start at all now. I checked to see if Start sync light comes on in Aem tuner. That makes me believe the cam and crank sensors are working correctly. Since then I’ve checked compression, spark and injectors are working to my knowledge. I didn’t touch the tune from when it drove to now. I checked the MAP sensor and I show 0.8psi with the car not running. I don’t think that is to far off for the car not to start. The car doesn’t even chug at all.
I’m really lost and could use some ideas or advice.
