1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Fuel pump relay harness is MISSING
Posted by Michael iffla, Nov 5, 2018
Please Support ExtremePSI
  1. Michael iffla
    Michael iffla Probationary Member
    11
    Joined Nov 5, 2018
    Pflugerville, Texas
    8E1C02D8-CC49-42BC-A532-C9C07EFCD06A.jpeg 75799971-C876-4C1A-BB90-5E2C58A9E416.jpeg 96 eclipse fuel pump no power, checked the continuity of wire around from pump to a driver side. Read the relay is located passenger side inside the console. As this is a restoration for me, the entire dashboard is out as it’s being restored, since it’s off I searched and searched for the relays came to conclusion previous owner ripped them out.
    Long story short, needing to know how to take the fuel pump harness wires ( 2 wires, assuming 1 pos and one neg) and directly rerouting power for it in the fuse Box that has power only when ignition acc is turned on.
    Any help? I prefer direct contact if possible maybe Facebook or Snapchat. Can also follow on my restoration project and process
    Log in/Register to remove ads
    My DSM:
    1996 Mitsubishi Eclipse N/T
    Street Build
      manual
    Loading...
    Featured Products from our Supporting Vendors
  2. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    3,211
    1,045
    Joined Nov 14, 2013
    Independence, Kansas
    My DSM:
    1992 Eagle Talon TSi AWD
    Street Build
    14b   automatic
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 MPH
    13.612 @ 107.760 MPH
    Loading...
  3. Michael iffla
    11
    Joined Nov 5, 2018
    Pflugerville, Texas
    Guess I’m a idiot because as self explanatory that is to y’all it’s confusing to me. I only have 2 wires coming off my fuel pump. ( black with blue strip with silver dots, and one straight black)
    I’m not sure how the key in ignition work turn on and off the pump if it’s straight to battery. That’s a consent power going to pump.
    If the diagram is 1st grade language can we like go to. Pre k for me LOL
    My DSM:
    Street Build
      manual
    Loading...
  4. 1990TSIAWDTALON
    3,211
    1,045
    Joined Nov 14, 2013
    Hows this? The square box is a normal 30 amp 12 volt relay you can get at any auto parts store. Run your battery wire from the battery to the pump and then install the relay back there per the diagram. This will fire up the pump any time you turn the key on.
    If you need more, just ask. Use 10 guage wire or heavier for the battery to relay wire and for the pump ground.
    Click on the picture to make it bigger.
    My DSM:
    Street Build
    14b   automatic
    Loading...
  5. jinscho
    jinscho Proven Member
    221
    75
    Joined Jun 16, 2017
    Bangor, Pennsylvania
    My DSM:
    1999 Mitsubishi Eclipse Spyder N/T
    Street Build
      manual
    Loading...
    1990TSIAWDTALON likes this.
  6. Michael iffla
    11
    Joined Nov 5, 2018
    Pflugerville, Texas
    Is it safe to say fuel pump does not work, took the two wires coming off fuel pump harness connected the straight to battery. Did not hear a wine or buzz since it’s straight to battery does fuel pump not work? Or am I missing something
    My DSM:
    Street Build
      manual
    Loading...
  7. dustyboner
    dustyboner Proven Member
    615
    185
    Joined Mar 13, 2016
    abq, New Mexico
    420a cars have the fuel pump relay on the firewall
  8. Michael iffla
    11
    Joined Nov 5, 2018
    Pflugerville, Texas
    I don’t have anything like that on my fire wall
    My DSM:
    Street Build
      manual
    Loading...
  9. dustyboner
    615
    185
    Joined Mar 13, 2016
    abq, New Mexico
    Its gotta be there somewhere. All years of 420a cars have the fuel pump and ASD relays on the firewall
  10. Michael iffla
    11
    Joined Nov 5, 2018
    Pflugerville, Texas
    I found it guys the old owner shoved it towards the bottom of the engine bay. Got a mounting bracket and worked. Ended up changing fuel pump and fuel tank as well. Due to insane amount of rust.
    Now next question. I drove it after repairs were done for about 2 miles, came home and sat in drive way in idol for about 30 mins, car just shut off, no shutter just as if someone turned key to off position couple trouble shoot errors came to conclusion the fuel rail has NO pressure the valve doesn’t leak any fuel whatsoever ever.
    Tips?
    Attached the rusted fuel pump and tank
    My DSM:
    Street Build
      manual
    Loading...
  11. jinscho
    221
    75
    Joined Jun 16, 2017
    Did you check to see if it's a clogged fuel filter? With how bad that old pump is I wouldn't be surprised if the filter is all gummed up too..
    My DSM:
    Street Build
      manual
    Loading...
  12. Michael iffla
    11
    Joined Nov 5, 2018
    Pflugerville, Texas
    I haven’t checked filter I plan on putting new one in tokorrow, but wanted to just change out the rest of everything that could go bad
    My DSM:
    Street Build
      manual
    Loading...
  13. jinscho
    221
    75
    Joined Jun 16, 2017
    I would pop the filter off and see if you have fuel flowing out the other end when the key is on. If you have pressure before the filter, but not after, you found your problem.
    My DSM:
    Street Build
      manual
    Loading...
  14. Michael iffla
    11
    Joined Nov 5, 2018
    Pflugerville, Texas
    So is there no fuel pressure regulator?
    I just wanna know I guess if the filter isn’t the problem ( I have a 99% certainty it needs to be changed) what would be another issue I need to step to down the fuel lines to rail to injectors.
    Sorry to sound like a broken record but the fuel pressure regular (FPR)
    My DSM:
    Street Build
      manual
    Loading...
  15. jinscho
    221
    75
    Joined Jun 16, 2017
    The regulator is on the end of the fuel rail just before the return line. If you have no pressure before the rail it's either a dead pump, or a clogged filter.
    My DSM:
    Street Build
      manual
    Loading...
  16. Michael iffla
    11
    Joined Nov 5, 2018
    Pflugerville, Texas
    Cool thanks, I hear it prime up each time I turn key. So filter or FPR.
    My DSM:
    Street Build
      manual
    Loading...
  17. dustyboner
    615
    185
    Joined Mar 13, 2016
    abq, New Mexico
    i can't remember when the FPR switched from the fuel rail to back by the fuel tank. so if you can't find our FPR on the fuel rail, look under the passenger side of the of the car, just in front of the rear wheel.
  18. Michael iffla
    11
    Joined Nov 5, 2018
    Pflugerville, Texas
    Thank you, I got side track today so I’ll be doing it tomorrow will update
    My DSM:
    Street Build
      manual
    Loading...
  19. Michael iffla
    11
    Joined Nov 5, 2018
    Pflugerville, Texas
    Found regulator under car directly inline with fuel filter it’s DEFINITELY hard to reach spot even when fuel filter is off, I’m not sure how to remove it such a tight spot and can’t really tell which size the bolt is. You do however need a wrench to remove the bolt. Sockets will NOT WORK. Picture attached
    My DSM:
    Street Build
      manual
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
