9!'clipseDOHC
Moderator
- 4,906
- 452
- Aug 24, 2003
El Paso,
Texas
DSMtuners.com SCCA SOLO Autocross Guide
Below is a quick reference guide for selecting a SCCA SOLO Autocross class. For full rules, download the 2012 SCCA Rulebook. The following guide applies to the 1990-1999 Mitsubishi Eclipse, Eagle Talon, and Plymouth Laser models. Any modification in a lower class can also be used in a higher class. Any modification not specifically allowed is prohibited.
But first, what is Autocross? Autocross is a type of amateur racing event focusing both on driver skill and vehicle handling and performance. Most Autocross events take place in parking lots or abandoned airfields with cones laying out the course. Because of this they are found all over the country and are more affordable then road course racing events. They generally feature speeds no faster the what you would encounter on a public highway. Autocross events build driver skill, provide a safe outlet for performance driving, and invoke some serious competition!
SCCA Autocross, also called SOLO, is based on a PAX index, which is basically a handicap designed to equalize all cars and focus on the driver's skill. Cars are placed into classes based on the type of car and modifications done. Each class is assigned a PAX modifier which is multiplied to your raw lap time to equal your PAX time, which is what is scored. For instance, an all stock GSX in DS has a PAX of .821 while an all stock GS has a PAX of .799. If the GSX ran the course in 60 seconds, his PAX time would be 49.26 (60x.821=49.26). So, for the GS to beat him, he would only need to run faster then a 61.65 (49.26/.799=61.65).
Ready to get started? To find races near you, click the Find Your Region link from the SCCA website.
Stock Class:
The stock class provides a nice way to be compete without spending a whole bunch of money on performance parts. However, since most DSM's are now 13-23 years old, they have at least a few modifications done that will bump them up in class. Even something as simple as a hacked air can, a downpipe, or a performance clutch will prevent you from being eligible to compete in the stock class. In the stock class you can run DOT legal R-compound tires such as the Hoosier A6, Goodyear Eagle RS, Hankook Z214, and Kumho V710.
Engine Mods Allowed:
OEM style drop in air filter in stock "unhacked" air can.
Cat-back exhaust
Any spark plugs or wires
0.020" overbore w/OEM cast pistons of same weight and CR
Oil catch cans (provided the PCV still functions)
Silicone hoses
Suspension and Brake Mods Allowed:
DOT legal tires regardless of treadware rating
Shock Absorbers (OEM Style, no more than 2-way adjustable)
Substitution, addition, or removal of a single anti-roll bar and supporting hardware
Aftermarket wheels (OEM width & diameter, offset within +/- .25inch including spacers)
Extended wheel studs and aftermarket lug nuts
SS Brake and clutch lines are allowed for cars 89-92 model years only
OEM fitment Brake pads of any material
"Speedbleeders" are allowed
Alignments must be made with OEM allowable adjustments
Other Mods Allowed:
Aftermarket gauges
Turbo timers
Grounding kits
Dataloggers
Hood pins
Alternate steering wheels (within 1" of OEM diameter and must retain airbag if originally equipped) and shift knobs
Spare tire, tools, and jack my be removed
Roll bars and cages
Scattershields
Street Touring Class:
The street touring class is designed around using normal, every day street tires. It is for this reason that it has a nice low PAX and also allows for a large number of basic modifications to help turn your daily driver or street car into a well-rounded autox car. It is also generally a very affordable class to race in with basic mods most people do anyway and without the high cost of dedicated track wheels and tires. The tires of choice for street touring are the Dunlop Direzza Sport Z1 Star Spec and the Hankook R-S3, although any extreme/max performance summer tire will still work well.
Lightweight battery (must be 12 volts)
Battery may be relocated to the trunk
Baffled oil pans
Intake system up to the turbo inlet for turbo car or throttle body for N/A cars. (MAF must remain in stock location)
Exhaust manifolds, headers, downpipes, high flow cat.
ECU tuning using V3, piggybacks, chips, or flashes (except boost control must remain stock)
Lightweight pulleys
Polyurethane motor mounts
LSD: STX AWD - No aftermarket LSD's can be added, STX FWD - Any LSD can be added, STC - No LSD's can be added
Any struts including coilovers
Lowering springs
Polyurethane suspension bushings
Adjustable camber plates
Camber bolts
2-point upper strut bars may be added front and rear
Substitution, addition, or removal of any anti-roll bars
Tires must have a minimum treadware rating of 140
Maximum tire width: STX AWD - 245, STX FWD - 265, STC - 225
Maximum rim width: STX ADW - 8", STX FWD - 9", STC - 7.5"
Any metal brake rotors (must be equal to or larger then stock, can be drilled or slotted)
Any calipers (must have same or greater number of pistons)
SS brake lines
Brake air ducts
ABS may be disabled but not removed
Other Mods Allowed:
Front seats may be replaced (New seats must weight at least 25 lbs and be fully upholstered)
Mud flaps, rear wings, front lips, fog lights may be removed
OEM wings my be added from other DSM's
Any steering wheel (must retain air bag if originally equipped)
Fender lips may be rolled but not cut or flared
Street Prepared Class:
The street prepared class is where you start to see some more power and are again allowed to race on DOT legal R-compound tires. You can up the boost and add in the supporting mods like fuel, clutch, and intercooler. However, the added power can often be more of a hindrance then a help to new drivers. If that is the case, focus on the skills and seat time instead of more performance parts.
Any size fuel injectors, lines, pumps
Aftermarket intake manifold
FMIC of any size
Aftermarket reticulated bypass valves may be used (this also allows the use of a 1g bypass valve on a 2g)
Manual boost controllers
ECU tuning (including boost tables)
Water injection systems
Any exhaust (as long as it is quiet and terminates behind the driver)
Upgraded radiators (must mount in same location and must be the same size or larger)
Cooling fans and shrouds can be changed
Any clutch and flywheel
LSD's are allowed to be added
0.0472" overbore w/OEM cast pistons of same weight and CR
Intake and exhaust ports and opening my be port matched up to 1"
Adjustable Cam pulleys
Wheels of any diameter, width, or offset may be used
Wheel spacers
Any brake line, master cylinder, vacuum brake booster, or brake pro- portioning valve may be used.
Other Mods Allowed:
Remove A/C system
Any steering wheel can be used (even if it removes the airbag)
Any fully upholstered front seats can be used regardless of weight
Front lips can be added
Rear spoilers may be added (can not extend more then 10" from the bodywork in any direction)
Fuel cell can be installed (must be within 20% of factory capacity and mounted within 6" of original)
Radio and speaker can be removed (but not the wiring)
Sunroof cars can be converted to solid roofs
Rear view mirror and sun visors can be removed
Street Modified Class:
To be fully built in the street modified class takes a lot of time and money. It also pushes the border between street car and race car. Yet in spite of this, most DSMers wind up in this class due to previous mods. A carbon fiber hood, turbo upgrade, or atmospherically vented BOV by themselves will land you in this class. If you find yourself here, don't despair, it just means you have the ability to do more mods without jumping classes! The big thing here is upgraded turbos. Chose wisely and try to balance between quick spool and high power!
Engine swaps with other DSM's
Any fuel system (5 gallon minimum fuel cell. Fuel cell must be at least 6" away from the ground)
Metal motor and drivetrain mounts
Any turbo
Any ignition system
Blow off valves vented to the atmosphere
Any drivetrain
Any brakes (except for carbon or ceramic rotors)
Other Mods Allowed:
Carbon fiber or fiberglass hood and front fenders
Rear passenger seats and seat belts my be removed
Spliters, spoilers, and canards can be added
Aftermarket side mirrors my be installed (must have 15 sq. in. of reflective material)
Pop-up headlights can be converted to static headlights (must retain high and low beams)
Stock Class:
- DS: Turbo/AWD PAX: 0.821
- GS: Turbo/FWD PAX: 0.814
- HS: Non-turbo/FWD PAX: 0.799
Cat-back exhaust
Silicone hoses
Other Mods Allowed:
Aftermarket gauges
Turbo timers
Grounding kits
Dataloggers
Hood pins
Roll bars and cages
Scattershields
- STX: Turbo/FWD/AWD PAX: 0.822
- STC: Non-Turbo/FWD PAX: 0.820
Baffled oil pans
Lightweight pulleys
Lowering springs
Camber bolts
SS brake lines
Brake air ducts
Other Mods Allowed:
- ESP: Turbo/FWD/AWD PAX: 0.848
- FSP: Non-Turbo/FWD PAX: 0.838
FMIC of any size
Wheel spacers
Other Mods Allowed:
Remove A/C system
- SM: AWD PAX: 0.866
- SMF: FWD PAX: 0.852
Any turbo
Any ignition system
Any drivetrain
Other Mods Allowed:
