dacowgod
Supporting Vendor
- 447
- 211
- Feb 3, 2006
Morgantown,
West_Virginia
PLEASE LIKE SHARE OR BUMP THIS AD!
This offer runs from now until Tuesday 11/27
I have an in house Mustang AWD Chassis Dyno located in Morgantown WV at RIX Racing
I am offering a free remote tune for a DSM or EVO with any parts sales of $500 or more..
I am offering 3 free Dyno pulls for those within my region for sales of $250 or more...
I also have 5000 SQ/FT of DSM and EVO Parts under roof.. dont hesitate to ask this list is NOT COMPLETE
Located in Morgantown WV
304-813-2405
1g ECMLink V3 Lite w/ 1990 ECU - $475
1g ECMLink v2 with 1990 ECU - $425
Cleaned and Flow tested FIC 1120s - $255
Recently rebuilt Genuine MHI EVO 3 big 16g Turbo - $425
EVO 8 Brake calipers (front and rear) - $500
Worn evo steering wheel - $150
EVO LSD Rear differential - $550
Brand new HKS Purple Timing belt - $150
Built Eagle/Wiseco 6 bolt short block - $1750
AEM Digital boost gauge - $100
AEM Tru Boost - $225
Full blown 2g dual fuel pump hanger - 10 feed -8 Return (Anodized purple) w/ 2 FSS 255 pumps - 425
NRG Front Seats w/ 2g Wedge engineering Brackets - $700
Cleaned and flowtested ID 725 Hi-Z Injectors - $350
2g Skunk2 coilovers w/ Tokiko Blue struts - $450
Brand new 2g/evo Oliver Billet "Ultralight" Rods - $625
Used DNP Style exhaust manifold (DSM Flanged) - $50
Chinese 16g in good shape - $75
2g black box ECU - $75
BBK 62mm DSM Throttle body - $150
Accufab 75mm Throttle body (Mustang flange) - $150
3g "No Tick" Lifters - $65
Genuine Greddy type "RS" Bov - $75
ARP 6 bolt head studs - $50
ARP 7 bolt head studs - $65
Walbro 255 pump (2g) - $40
Ported Throttlebodies.com 63mm Non turbo Throttle body - $125
4 bolt manual rear end w/ axles and cups - $400
2g GST 5 speed Transmission - no grinds - $350
2g GST Auto Transmission - shifts as expected - $400
2g ECMLink SD harness - $50
JPipes Jpipes Jpipes!- $25
Complete 2g AWD Auto swap in good shape(Includes everything to make your manual AWD an auto AWD) - $1250
Good pull stock 6 bolt head - $225
Good pull stock 7 bolt head - $225
Billet Unorthodox Racing Aluminum crank pulley - $40
Good stock 2g Auto transmission - $700
ACT 2600 pressure plate - $125
ACT 2100 Pressure plate - $125
good low mileage ACT 2600 clutch kit - $275
Act Streetlite 7bolt fwd flywheel - $100
Braille - Small battery tie down/tray - $85
Good 2g MAF - $25
os giken DSM twin disc clutch - worked well but will need a rebuild - $450
2g LSD Manual Rear Diff - $225
2g Non LSD Auto Rear end - $200
2g 91-96 Auto Tcase - $150
22 spline manual tcase - $150
23 spline manual tcase - $150
Good manual half shafts w/ carrier - $75
Cleaned and flowtested Stock 450 DSM injectors(Blue tops and black tops) - $75 per set
Cleaned and Flowtested Rc 550 injectors - $100
Cleaned and flowtested EVO 550s - $100
Recently rebuilt to stock 1g head - $300
1g Head with EVO 9 springs/retainers - $350
1g head with BC Springs and retainers - $375
Good Engine harnesses (1g/2g Auto and 5 speed available) - $150
2g prothane motor mounts (Manual) - $75 (includes the mounts and inserts)
Uncracked valve covers - $75
2g Tokico blue suspension w/ tokiko red springs - $325
Rebuilt PTE 4431e bolt on Turbo - $525
cleaned and tested RC 1000cc injectors - $250
Tial f38mm wastegate (Stripped fitting will need repaired) - $75
PLEASE CALL OR TXT
304-813-2405
304-813-2405
Good 2g MAF - $25
PLEASE CALL OR TXT
304-813-2405
