Please Support ExtremePSI
Please Support STM Tuned
Cylinder head side port? Missing bolt?
Do I need to plug it? Is there oil or coolant behind it?
i believe that pic is a generic pic from the internet.
have you checked your own cylinder head by poking inside the hole?
it doesn't seem to be a through hole to the other side of the head.
it might be bending towards the cylinder head and block mating surfaces, and may be a coolant port.
not sure though as my cylinder head's at another place.
but i remember that only oil ports were the ones plugged.
I got my head back from the machine shop and wasn't sure if i neded to plug it. i put the head on the car and noticed the plug. i got the timing cover on already. need to take it apart i guess
I'm not sure anything actually goes in that hole. All the oil galleries were drilled/plugged from the opposing side or through the top.
Turns out it does not need to be plugged. I filled the car up with fluids and cranked it over. Nothing came out so it looks like it's ok without a plug.
