BogusSVO
- 5,891
- 318
- Jul 1, 2009
Pensacola,
Florida
1997cc (2.0) DOHC,16v,Vin Y, 1995-99
Some part numbers for
1996cc (2.0) DOHC, Vin Y 1995-99
Avenger, Neon, Sebring
From the SBI Parts catalog, Block 16
Valve Int 01730 1.370 Head dia
Exh 01731 1.201 Head dia
Takes a single round bead on the mitsu, the Chrysler takes a triple bead valve lock. Valves can be interchanged form one head to the other, as long as the proper match valve lock is used. Springs and retainers are the same on both heads.
Valve spring 160-1347 1.840 tall
Spring OD 1.027
ID 0.731
Closed [email protected]
Open [email protected]
Solid @1.100
Max lift .440
Valve stem seal 122-1251 Postive, top hat style
Cylinder head thickness
SBI New head height 5.411 -5.419
Min Heigt 5.403
Max removed .008 - .016
Block32 (page 98-99)
148CI, 2.4l, DOHC,16v, Vin B, J, X 1995-2007
Breeze, Caravan, Cirrus, Grand Caravan, Grand Voyager, PT Crusier, Sebring, Stratus, Voyager
Valve, Intake (1995-99) 01730 1.370 Head Dia 1G
(2000-06) 02008 1.370 Head Dia 3G
Exhaust (95-99) 01731 1.201 Head Dia 1G
(00-06) 02009 1.201 Head dia 3G
Valve spring 160-1426
Free length 1.905
Spring OD 1.044
ID .740
Solid 1.112
Max lift .384
Also add
Block 33 (page 99)
Vin E,G,S. 2003-06 (Turbo Engine)
Hase the inconel factory valves.
Neon SRT-4,
Valve, Intake (2003-05) 02034 1.370 Head Dia. 3G
Exhaust (03-05) 02035 1.201 Head dia 3G, Inconel
Spring OD 1.027
ID 0.731
Solid @1.100
Max lift .440
Min Heigt 5.403
Free length 1.905
Spring OD 1.044
ID .740
Solid 1.112
Max lift .384
Also add
Block 33 (page 99)
Neon SRT-4,
