msisto
- 37
- 2
- Jun 30, 2018
Rochester,
New_York
Hey All,
I have a stock 98 GST with an AWD swap. I was driving to an appointment recently when I got a misfire in cylinder 2 (code P0302). This was accompanied by code P0202 (Injector Circuit/Open - Cylinder 2). My injectors are rebuilt ones, but I tried swapping out cylinder 2’s injector with a known-working one. No luck. Then, I tried swapping the plug from cylinder 2 with an adjacent one. The misfire followed cylinder 2’s plug, so I narrowed it down to either the harness or something it is connected to. I checked the resistance across the two receptacles in each receptacle that plugs into each injector. All of them gave me 400kohms of resistance except for injector 2’s receptacle, which read around 3Mohms - pretty low.
Is this indicative of a bad resistor pack? Could it be the ICM?
