Please Support ExtremePSI
2G Crankshaft pulley moves at idle
Heryst78
121
11
Feb 9, 2017
Paris, Europe
Hello everyone
I come to you because, for months, my eclipse makes a belt noise at startup only, and when I accelerate between 1000 and 1500 rpm.
I just noticed that this is my crankshaft pulley.
To describe what is happening, it seems to turn as if the pulley itself was deformed, and so it causes a noise because the belt does not rotate perfectly.
When I accelerate a little, the crankshaft pulley goes straight and it makes no noise.
I'm scared of the Crankwalk, can someone tell me if there have ever been deformed crankshaft pulley subjects?
Thank you
I would stop driving it immediately. It sounds like your crank pulley is starting to separate. There is a rubber ring inside of the pulley and it’s most likely deteriorating. If it fully separates, it’s not gonna be pretty. Here’s where to look
Hi and thank you for your answer !
I know that behind my crankshaft pulley, it is already missing pieces of metal, it looks like it is already broken in fact.
I have not seen an apparent crack, but (I do not know if you understand me because I'm French and I use google translation to write to you), at idle, it runs correctly except it looks like it deviates from its trajectory, a bit like a top that loses its speed, you see what I mean?
When I accelerate, the pulley no longer quote its trajectory.
Thank you :)
Thank you :)
It's a pretty good guess your crank pulley is bad and you should replace it. Take it off and inspect it. If it's that bad its probably ready to separate and may even fall apart on your hands. It is a common failure.
Thank you :)
Such a common problem and a quick fix if you catch it in time.
I would not drive at all until it’s changed
GOOD LUCK
C R A N K W A L K ! ! ! l o l jk. Yea change your pulley ASAP. The rubber bushing inside the pulley itself wears out. Remember, these cars are old as hell now. Parts age, rubber ages.
Hi guys,
After disassembly of the pulley, indeed, she is dead :)
I put you some pictures, and indeed, the rubber bushing is dead, I put you a video on Youtube so that you can see what it does LOL
I ask Miller to send me one in France, because the import tax on new products is very very very expensive! :)
Thanks again :)
Hi guys,
Thanks again :)
You were lucky. That outer ring has been known to go inward and take out the timing belt.
