Turbodhi
- 115
- 10
- Oct 18, 2015
Olathe,
Kansas
hey guys, I'm working on my 2g and when I tried to pressurize the cylinder so I could compress the spring, the crank spun. I don't know which direction it spun and I don't know if that means I now have to do timing. I unbolted the cam gears from the cams and had the belt still on it. I didn't see the timing belt move but I saw the accessory belts move. also should note that my cams where out when it spun so the only thing that moved was the crank.
