Please Support STM Tuned
2G Can i use these injectors?
181161
107
37
Mar 19, 2011
El Paso, Texas
I have this set of injectors and I am not sure that they will work for my car. They are a set of Bosch injectors pn 0280150842. They fit the fuel rail but just sit on the head. Not so much insert as the stock ones do. They appear to be 1600cc but what I want to know is if that tip is compatible to be used with our cars. Thank you
Here they are
if they fit and connect sure you can
Those old ford blue tops have a huge nonlinear flow area around 2ms. It makes it impossible to have them idle at stoich with gas. And usually give a hiccup at cruise. Wot will dial in fine though.
ID1050x and ID1300x will idle nicely.
