motomattx
- 3,955
- 1,621
- Dec 9, 2010
wampum,
Pennsylvania
JB weld is not going to hold anything, its way too weak to do any good against the forces of an engine part, if it makes you feel better then go ahead, but when it comes down to push and shove the epoxy will just fall out. I would say that resonation in the crankshaft is whats causing the bolt to come loose, as the crank resonates and the threads in the crankshaft expand and contract along with the spinning of the crank, there are times that the stretch from the bolt is negated alowing the bolt to work its way out a little bit, the damage to the gear and keyway if from fretting that is happening over time rather than all at once, I dare say that if you pull some main bearings they may show some signs of fretting as well. You could use Loctite bearing and sleeve lock around the crankshaft to gear mating area, its a product thats made for that, regular Loctite isnt going to work other than on the threads due to it being anaerobic.
