Inkdlyfe
- 438
- 7
- Feb 23, 2016
Summer feild,
Florida
So I just did my HG not even 3 miles ago MLS with ARP torqued etc, I started it multiple times after this moved it maybe 3 miles total, started the car last night idles still for I'll so 20 mins started to get hot car is turboed so I figured that' ok with no Breeze or fan going just wanted to make sure i had no boost leaks or vac leaks checked out all good turnt the car off went to start it today and turnt turnt turnt nothing sounded like I was trying a compression test with the motor all together, thought the plugs came loose so checked them nope all good, and on time for sure, did a comp test first one read 0 no change at all got a new test and the 1st one read only 30 after 10 turns rest 0 maybe moved 1 cm, went back to the 1st and that one read 0, oil seems ok very very minor milky color on the cam cap bolt tops but not on vc, dip stick, or oil cap there all good looking, should I try another comp test ? What are the chances I blew a hg on I'll say 3 1/4 mile test runs ? Fully built motor just a fyi and yes head and block been decked when HG was installed
