1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Anyone Ever Use Caster Plate with Whiteline Caster Bushing Together on 1g?
Posted by talon77, Dec 5, 2018
  1. talon77
    talon77 Proven Member
    105
    23
    Joined Sep 12, 2004
    annapolis, Maryland
    I happen to be perusing the 1g Roadrace Setup Guide on this site and saw the following recommendations:
    http://www.dsmtuners.com/threads/1g-dsm-road-race-setup-guide.476777/
    - "RRE Camber Plates, specifically, the ones that add caster to further improve handling and give you more adjustment points depending on the track."
    http://www.roadraceengineering.com/parts/camber_plates/1gco-caster.jpg
    - "consider Whiteline's Caster Correction bushings. These offer a significant improvement in overall stability over the stock bushings. The increased durometer or stiffness combined with the offsetting design help retain and add caster which will, in turn, help improve straight-line acceleration and hard braking, cornering, and steering response."
    http://www.dsmparts.com/customer/product.php?productid=406&cat=41&bestseller=Y
    I would like to know if anyone here followed the recommendations on that Roadrace setup guide and actually have BOTH of these items installed in their 1g DSM. What is your experience on how it made the car handle at the track? I am wondering if installing both of those items could result in TOO much caster, if that is even possible. Thoughts?
    Reason why I'm asking is because I'm planning to install the Whiteline caster bushings this winter and I'm also considering either RRE caster plates (fixed caster) or the Ground Control Caster plates (adjustable caster). If I end up overdoing the caster, I can reduce it as needed with the Ground Control, but if I get the RRE then I'm stuck at that caster setting. Thoughts from anyone with Whiteline Caster Bushing AND Caster Plates?
    Here are the adjustable Ground Control Caster Plates:
    https://groundcontrolstore.com/coll...pse-talon-not-galant-pair?variant=36732067587
    Thanks!
    Log in/Register to remove ads
    My DSM:
    1994 Eagle Talon TSi AWD
    Road Race Build
    345 whp   318 lb/ft
    Loading...
    Featured Products from our Supporting Vendors
  2. pagosa dsm
    pagosa dsm Proven Member
    310
    10
    Joined May 7, 2005
    pagosa springs, Colorado
    I did both. At this time I have Ground Control camber caster plates with steel rear bushings on the front lower control arms. I have 5* positive caster on it
    My DSM:
    1992 Eagle Talon TSi AWD
    12.084 @ 118.930 MPH
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
