snooopy365
- 198
- 3
- Jan 25, 2003
XX,
Europe
Hey,
just want to share my impression.
I did some "stuipd" thing to my little NT engine.
My old car got into an accident (engine still good).
So I got an other DSM.
An GS, because turbo cars where never sold in germany.
The differents between US-NT Gs and germany GS are:
10.4:1 compression.
Knocksensor
Oilcooler.
Because of the old car, I had some parts laying around:
- 2G MAS
- 2G knock sensor
- 255lph walbro
- aAFR
- 4* 840ccm FIC Injectors
- "Resistorpack"
- Evo8 Ecu.
So I fitted the NT car with custom E85 maps (stock Evo maps are pretty much unuseable in a NT car.
I did wire the resistors directly in the harness adapter to the Evo Ecu.
Than I streettuned it.
The results did amazed me pretty much.
Stock the car did feel weak until 5000rpm, than it runs strong upto 6000rpm, than it is feeling weak again.
After the modifikations the car is running strong since 4000rpm.
Than hits a power peak at 6000rpm but keeps the power until my risen rev limiter stops forward motion at 8000rpm.
I haven`t dynoed the car, but my butt-dyno tells me its more than 175hp.
I`ve let a few GST owners drive the car and they say its just a little bit slower than a stock turbo DSM.
I timed acc from 0-60mph with evoscan.
Stock time for this is 9.3seconds.
But I should mention that it normaly take a gear change to reach 60mph... with 8000rpm limiter that is not nessary.
And yes the car is realy running over 40 degress timing on WOT.
If you like to see a video of the car running:
YouTube - Evo Ecu im Eclipse mit E85 Anpassung.
but it does have german text in it
and some bad quality video of reving upto 8000rpm.
YouTube - Reving stock head to 8000rpm
and last but not least just a little "soundcheck"
Car is running lean (lambda 1.3) and very agressiv timing
http://www.youtube.com/watch?v=fQj5oh1GueE
exhaust is stock.
So my final thought:
Is it good to run an Evo Ecu on a NT car?
YES, with custom timing maps its just great.
But honestly, it might be cheaper to get a turbo car
Why did I do it?
Because I just had the parts laying around and wanted to try tuning with an evo ecu, before my turbo engine is in the car.
Hope somebody find any use for my input.
10.4:1 compression.
Knocksensor
Oilcooler.
- 2G MAS
- 2G knock sensor
- 255lph walbro
- aAFR
- "Resistorpack"
- Evo8 Ecu.
exhaust is stock.
Why did I do it?
