Please Support Rix Racing
Resolved 98 gsx awd auto pull it out of park but wont move
Chapmanwired13
34
Aug 4, 2018
Mandan, North_Dakota
I have a 98 gsx that I just bought , has 6 bolt swap . Has new transmission but when u pull it out of park it doesn't move. It doesn't do anything in any gear.
Solution
Turns out no adapter plate, so I have to rebuild and replace everything, trans, pump, converter, seals.
Thanks everyone that replied and helped me out
Here is my 6 bolt auto block. Do you have the gold spacer plate that goes between the block and the trans? If not what Bryan said is correct.
That's just a sticker from the company that rebuilt your transmission. The plate I'm referring to can easily be seen right by your turbo and water pipe.
Ok thanks man. I work almost 80 hours a week so I have a buddy that works at a shop so hes gonna give me a diagnosis. Whether it's the pump or that adapter plate, and then fix it as long as I buy the parts.
Solution
