Cougar232
- 50
- 1
- Aug 1, 2011
Shenango Valley,
Pennsylvania
I had a buddy come down from Michigan to Hermitage PA 16148 to assist with the swapping of my leaking 98 Spyder Turbo OEM (99k miles). We got everything disconnected and I have 1 bolt on rear tranny mount stuck(Mapp gas couldn't break it either). But I dont want to disconnect engine and lower by myself I almost have enough clearance but stuck on converter and I'm sure I'm not pulling it out properly myself and need experience. I do have it 1inch off the motor and can see flexplate and start of converter. I am willing to Pay$$ for the labor to swap in the other auto tranny and its 1 bolt and old tranny is out. All bolts labeled in zip lock bags and have everything on site besides small compressor/air tools may help put back together but not required unless you have. please If someone can get down here on the weekend or on a Friday or Monday I will even take a day off of work if needed too. I can also arrange a hotel overnight if needed, but this should be a full day at most with re-assembly, just need this work done by someone familiar with DSM. I am ready and car is 1 bolt and we can drop motor if it helps it clear. I really need someone that can do this ASAP! PLZ!. Thanks Cell 7248139710 . Phil
