1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
For Sale 95 Talon Tsi AWD Race Car Partout
Posted by dexterholland04, Oct 9, 2018
Please Support VR Speed Factory
  1. dexterholland04
    dexterholland04 Proven Member
    618
    84
    Joined Jan 1, 2007
    Rush, New York
    I am gauging interest in parting out my Talon. I'd like to keep the shell as a complete roller as it is a real clean car and literally has EVERYTHING done to it. However, I will (within reason) negotiate bits and pieces you may or may not want with it. I will not be selling any of the other parts until the shell is sold. I want to afford the buyer of the shell first-dibs on everything.
    This car weighed 2425lbs without a driver as a 5-speed with 5-gallons of E85...so, it's light. Probably a little heavier now that it is an automatic car.
    I can provide more pics as necessary to a serious buyer, and I'm sure this isn't an exhaustive list but it's close. I can answer any questions - feel free to PM me.
    The shell:
    1995 Talon TSi AWD (Paint Code G36 - Everett Green Metalic)
    - Clean NYS Title In-hand
    Body Parts:
    - Seibon Carbon Fiber Hood with pins
    - GT Fabrications Carbon Fiber Hatch with Stock Glass
    - Carbonetics Carbon Fiber Doors with Manual Windows
    - Carbonetics Carbon Fiber Sunroof (Epoxied in place - no sunroof tracks/motor)
    - 2GB Bumper and Headlights
    Chassis Improvements:
    - Fully gutted with a 10-point cage (will cert to 8.50)
    - Kirkey Aluminum Seat (17.5" Wide)
    - RCI Cam-lock Belt
    - 26" M/T Full Slicks on Rota Slipstreams
    - Stroud Parachute
    - 5 Gal RCI Fuel Cell with cover
    - Paul Volk Tubular Rear Subframe with an LSD Rear (Auto diff)
    - 8an Fuel Feed and 6an Return Lines
    - 2 Bosch 044 Pumps on an RCI Mount
    - Torque Solutions Carrier Bearing Bushings
    - DSS 3.5" Driveshaft
    - DSS Rear Axles
    - Properly De-powered Steering Rack with new Inner/Outer Tie Rods
    - Newer Stock Brakes (Calipers, Pads, and Rotors only have 2 passes on them and maybe 20 miles)
    - JM Fab Small Battery Tray
    - Hurst Promatic II Shifter and Linkage (Installed on to a Auto DSM Base so it's bolt-in)
    - Overkill Fabrications Bumper Kit (Dzus Fasteners)
    - Bumper exhaust hole with trim
    Gauges:
    - Stewart Warner Electric Trans Temp Gauge
    - Stewart Warner Digital Tach/Shiftlight
    - Stewart Warner Electric Oil Pressure Gauge
    - Innovate LC1 Wideband O2
    Electrical:
    I was in the process of making a custom harness for this car using all new connectors and wire. The harness itself is about 60% complete. I will include the rest of the connectors/pins/wire for you to complete it. I'll also include a lightened (working) stock harness and a stock auto engine and body harnesses I got with the auto swap stuff.
    PRICE: Negotiable, depending on what you want with it.
    Engine and Transmission (All are negotiable with the shell):
    2.0L 7-bolt with TurboTuff I-beams and Wiseco 1400HD (10:1):
    -> 2 Passes and about 20 miles on it
    -> Every nut, bolt, gasket on the bottom end is new OEM Mitsubishi
    -> Front-facing oil filter housing
    -> New OEM Front Case
    -> 1/2" Headstud Conversion
    7-bolt "Nasty Head" from Force Engineering (Ported and polished):
    -> New guides/seals
    -> Supertech dual springs
    -> GSC S3 Cams
    -> Kiggly Racing HLA
    -> Manly +1mm Oversize Valves
    -> HKS Old School Purple and Green Cam Gears
    -> OEM Evo Kevlar Belt and OEM DSM Tensioner
    Automatic Transmission:
    -> No miles on it
    -> Kiggly Clutches
    -> New consumables
    -> Translab Shift Kit
    -> Welded Center Differential (Paul Volk)
    -> All trans and valvebody work done by dacowgod - Ricky Nichols (Rix Racing)
    Precision Converter:
    -> No miles on it
    -> With Kiggle Flex Plate
    -> Larger than-stock ARP Flexplate Bolts
    Derale Trans Cooler:
    -> 6an Lines and fittings
    The rest of it (Also negotiable with the shell):
    - DSM Link v3 Full with EPROM ECU and Speed Density (Sensors and Harness)
    - Nitrous Express Wet Kit (Brand New)
    - RCI 2200cc Injectors
    - PTE 6466 (.81 Open T4)
    - Redjack Racing Exhaust Manifold (Open T4) with TiAL MVR and dumptube
    - 4" Bumper Exit Exhaust
    - TiAL BOV with 10psi spring (Purple)
    - Redjack Racing 7-bolt Intake Manifold with N/T Throttle Body
    - RCI Fuel Pressure Regulator (Just Rebuilt with new diaphragm)
    - VRSF FMIC Core with Custom piping (v-band couplers)
    PRICE: I will update prices on everything individually once the shell sells!
    Or, I'll let it all go for $15,000 cash.
    LETS TALK!
    Thanks,
    -Will
    Log in/Register to remove ads
    My DSM:
    1995 Eagle Talon TSi AWD
    10.1 @ 149.02 MPH
    Loading...
    seescooter likes this.
    Featured Products from our Supporting Vendors
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
