wing3r09
- 114
- 10
- Apr 14, 2012
MONROE,
Michigan
Been pondering the thought of building a 2.2l Destroker for my 99 gst that I will also be swapping to AWD.
The Reason for the idea is just something that I do not see a lot, actually never seen. Ive read that with the destroked engines you can rev crazy high, but is there a trans that can handle shifting this high?
Plans for the car include Big turbo, E85 (10:1 or + CR) , and 600hp. The reason for 600 is just because i want it (Street beast for my pleasure). The car will not be a DD but a weekend warrior on the street. So Is a 2.2 a good idea, or would a 2.3 be a better option, or should I just pitch the idea of stroking/de stroking the engine and stick with my 2.0 now.
To build the 2.2 below is what I found i would need, and in the same thread is the 2.3.
2.2 Destroker
Standard Specs:
Stroke: 94mm
Factory Bore: 86.5mm
Rod Length: 156mm
Wrist Pin Height: 1.248"
Displacement: 2209cc or 2.2L
Rod/Stroke Ratio: 1.65
Piston Speed @ 1,000RPM: 10.27 FPS
Pro's: More displacement than a 2.1 Stroker with equal rod ratio and piston speed.
Con's: Expensive due to the crank and rods.
Notes: None
2.2 Destroker
Standard Specs:
Stroke: 94mm
Rod Length: 156mm
Notes: None
