Please Support Kiggly Racing
Please Support Rix Racing
2G How to: 3g Eclipse shifter into 2g Eclipse turbo
ANY QUESTIONS PLEASE ASK! (UPDATED WIRING INFO 1/17/21)
wiring off of 3g shifter as follows -
1- Black - common wire for mode selection (grounded)
2- Red - common wire for shifting (ground with black wire)
3- Red/white - auto shifting mode (any time shifter is in P,R,N,D, will show continuity to ground)
4- Blue - manual shifting mode ( any time shifter is on the manual shift tiptronic will show continuity to ground and will deactivate auto shift wire/mode)
5- Yellow - up shift signal, (use down shift wire on shift box if you want to reverse shifter direction)
6- White - down shift signal (use up shift wire on shift box if you want to reverse shifter direction)
how to test what wire does what using a test light. hook test light clamp to a 12v+, then probe each wire while going though the 4 selections. its that simple. (IN ORDER TO USE TEST LIGHT METHOD, 3G SHIFTER MUST HAVE BLACK AND RED COMMON WIRES GROUNDED TO CHASSIS)
there is no info or picture or videos about this so i though i would start a thread about this topic,
@DogWhistle (Thanks) toward bottom of page thread, page 3. this link is for a boot install to hide the extra space after install if still using factory plastic's
https://www.dsmtuners.com/threads/sun-burned-’99-spyder-gs-revived.483010/page-3
mod; 3g (2000-2005) mitsubishi eclipse tiptronic shifter assembly in a 2g (1995-1999) eclipse turbo (gsx-gst)
3g shifter found at junk yard for $40
tiptronic will only work with some type of shift boxes ONLY.
all cables will plug right in except one (pictures below)
video shows setup that im running
all 4 bolt holes line up!!!
links to shift boxes. vvvvv
IPT---------------- http://www.importperformancetrans.c...ft-box-90-99-eclipse-and-talon-auto-5289.html
ForcedFour------- http://www.forcedfour.com/products.htm
RoadSurge------- http://www.roadsurge.com/products
