90laserRSfwd
- 1,412
- 84
- Mar 5, 2007
Elizabethtown,
Pennsylvania
Looking for technical advice, (or opinions) on building a bottom end. Needs to be able to easily turn to 9,500rpm on a regular basis (42r)
Not looking for advice on the rest of the build, just the short block. Wanting to do a 2L since it's a simple off the shelf build, but a 2.0 long rod is just as simple, then there's the 2.2 short long rod that I've seen another member post about
94mm stroke crank, 153mm rods, stroker style pistons I believe?
I'm very interested in the extra displacement, and if it's as simple as it sounds, I'd go the 2.2 route. I currently only have a standard 4g63 block (6 bolt) available to use as a starting point, I'm not interested in the 2.3L at all..
