Please Support Kiggly Racing
ECMlink 2G New fic injectors injbattetyadjust question
CORNF3DECLIPSE
3
Jul 28, 2018
LEWISTOWN, Pennsylvania
I got new fic 1220 injectors and I was checking out the chart they provided for voltages. Do I just copy what they provided and put that into injbattetyadjust? Check the picture i just wanna be sure i never did it ths way before.
I
Yes, but also read the link above.
I got screwed up somewhere. I'm at work right now but I put the voltages back close to stock because it was really rich over the weekend. But my global deadtime is at 365, my speed density table is screwy though and the highest cell is now 115 but its drivable.
So should i zero out my global deadtime and use fic's volatges for injbatteryadjust?
Also what do I do with the data sheets "injector offset matching data"
Thanks in advance to anyone that helps
The injector offset table is telling you exactly how much your injector flows. I would use the average number as a starting point for the global calculations. Put in your voltage values and start tuning. If you're VE table is messed up then you need to go back to stock or have someone create one for that's competent.
