Martin Arroyo
- 0
- Mar 30, 2018
Chicago,
Illinois
Hey Guys, I've had this problem for a while now. Seems I cant catch a break but I welcomed myself to the DSM world.
I have a problem with my 97 GSX, it started one morning after I fixed my misfire issue. Car started fine the next day drove it to a nearby store. Turned off, about 10 mins later turn back on no hesitation what so ever. Couple miles down the road it just shut off. Pulled over & try to start, all it did was crank and no start. Figured I was out of gas, filled it with a 1/4 maybe it was just drained but that did not fix my problem.
Was able to push it to my garage. Checked spark and fuel pump, have spark & fuel pump turns on. Checked my OBD2 scanner and I had a code for Crankshaft Position Sensor. I changed the sensor to see if that will be the problem, seems that it wasn't. I checked for damage around the new sensor (since I read in different forums that they break easily while installing) & wires but looks 100% good.
What am I missing here?
If you guys can help out a new member I would greatly appreciate it .
