1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
For Sale 2008 EVO X GSR Fully Built
Posted by Clipse3GT, Sep 27, 2018
Please Support Feal Suspension
  1. Clipse3GT
    Clipse3GT Probationary Member
    Joined Jul 23, 2015
    Cleveland, Ohio
    I'm finally putting my Evo for sale. Really enjoyed this car but I feel I need to move on to something else and go in a different direction.
    The car is setup to be street and autocross machine. It has been driven yearly and autocrossed. The car has normal wear and tear as parts wear out they get upgraded or replaced with OEM parts. Minor dings and rock chips over the years. Minor surface rust normal for 10 year car driven year round.
    The car is fully modified for running in SM autocross class with a fully operational interior.
    The car will not be parted out. Only selling as a whole. The wheel and tire combos will be sold separately if the buyer does not want them.
    If you have questions regarding the car please shoot me a message or email.
    I will prep the car for sale by a professional detailing company if the customer wishes.
    PRICE: $27,000 OBO
    Here it is in action at local AutoX Event!!!
    2008 Evo X w/ SSS package.
    VIN: #JA3AW86V68U050439
    No Accident History
    Clean Carfax
    Clean Title
    ~86500 miles on chassis
    23k miles on built 2.0L engine
    Body & Lighting
    All stock and original SS kit.
    Rally Armour Flaps
    LED DRL & REARS
    Interior
    All stock & everything is operational
    Added gauges
    AEM AFR
    VEI BOOST
    VEI OIL PRESSURE
    Engine
    Built Longblock 2.0L by Speedcircuit
    8500 rpm redline capable of 9k+
    Head
    SpeedCircuit Stage 2 Headwork & Valve Lash
    Deck the head to mate with block
    Cosworth MX-1 camshaft
    Ferrea 6000 Competition Valves intake & exhaust
    GSC Beehive Springs Comes with Ti retainers
    Ferrea Valve Guides
    ARP Head Studs
    Block
    86mm Arias 9.0:1 Compression Pistons
    Overbored 0.0010"
    Pauter Rods
    ARP main studs with an align hone and bearing
    ARP rod bolts
    OEM bearings
    Fully Balanced OEM Crank
    MAP Larger oil cooler
    Brad Penn 20W-50 race oil
    Transmission
    Stage 1 Shep 5 speed upgrade
    Shep Upgraded diff pins
    QM Street Twin Disc w/ hydraulic TOB
    Evo 9 Master Clutch Cylinder
    WORK Shifter Bushings
    TWM Short Throw Shifter
    TWM Cage
    TWM Shift Knob
    Suspension
    Ohlins DFV RT w/ 10kg Front & Rear Spings
    Cobb Front & Rear Swaybars
    Energy Suspension bushings
    Upgraded tie rods
    Whiteline bushings front and rear
    Whiteline RCK kit
    Whiteline Caster Bushings
    Whiteline front and rear endlinks
    Intake
    MAP 3.5" w/ Bellmouth w/ K&N Air Filter
    MAP Stage 2 PNP intake manifold
    SSP Intake manifold spacer
    MIL.SPEC Ported TB
    APS twin vent BOV
    HKS racing plugs
    Cobb UICP/LICP/BOV piping
    ETS 4.0" Racing Intercooler
    GM 3 port boost conversion
    Turbo/Exhaust
    FP Red Ballbearing & feedline w/ filter
    Fullrace exhaust manifold
    Forge WGA
    AMS bellmouth downpipe
    Tomei testpipe
    Tomei catback exhaust
    Torque solutions exhaust hangers
    FUEL
    FIC 1100cc Injectors
    Fuellab Regulator and gauge w/ inline filter
    AMS Fuel Rail & Fuel Lines
    Walbro 255HP fuel pump
    MISC
    Torque Solutions Front & Rear
    Torque solutions driveshaft bushing
    Torque Solutions rear carrier subframe bushings
    Beatrush rear diff bushing
    Beatrush rear diff side bushing
    SSP full under panel protection
    Perrin antenna
    MAP coilpack cover
    Speedcircuit firewall heatshield
    Speedcircuit camshaft sensor heatshield
    Upgraded relays
    DrivenFab V3 coolant expansion tank & catch can
    CP Performance breather cap
    New AYC pump coated built with SS internals and sealed
    Upgraded SS Hardware
    Tires & Wheels
    OEM GSR 18×8.5 w/ 245/45/18 Michelin Winter Tires (included)
    Advan RS 18x10 w/ Nitto NT05 275/35/18 summer tires (optional in package deal)
    Enkei RPF 1 18x10.5 w/ Hoosier A6 285/30/18 (optional package deal)
    Gorilla lug nuts
    Tune
    550 WHP & 430 WTQ @ 29 psi - Dynojet
    490 WHP & 380 WTW @ 24 psi - Dynojet
    93 Octane
    3 custom power maps with winter detuned mode
    Log in/Register to remove ads
    Featured Products from our Supporting Vendors
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
