cyrusthevirus
- 0
- Feb 7, 2012
mountaintop,
Pennsylvania
Hi all,
$26,500 or obo
It has come time for me to sell my favorite car. Just a short run down. The reason i am selling it is I am in the process of downsizing to one vehicle as a daily and I am also in the market of purchasing a house as well so i do not need 2 cars.
VIN: JA3AH86C66U043044
Clean Title in hand (Can provide vehicle report)
I have a ton of paperwork available to buyer as well documented service/work.
I think I still have the original window sticker.
Mileage 25,402 will go up alittle
located by the Wilkes barre Area in PA
Background:
I am the 2nd owner on this car. It was my friends. I purchased in back December of 2011. it has never seen the snow. Garage kept. This car was tuned by mellon.
The final number were 329hp 340tq. I have the sheet
I will continue to add more information and more pictures daily.
Thanks for looking,
You may Pm me about anything.
EXTERIOR CONDITION: 9/10, No dents rocks chips are minimum. The gel coat on the spoiler has worn thru. The trunk has started around the corners alittle bit.
INTERIOR CONDITION: 9/10 The steering wheel has wear. always being adult driven and taken care of it
shows.
ENGINE/DRIVETRAIN CONDITION: 8/10. Does not use up oil. i have been using amsoil oil since i have owned it. 4th gear some times has a bump. It maybe the sync going other than that it was with the car when i purchased it from the previous owner. I replaced the stock clutch roughly around 4500 miles ago with a stage 3 competition clutch.. I also installed a lightweight act flywheel and a My plans were to get the car over 400hp.
SUSPENSION/BRAKES: 9/10 original pads with Mars coilovers installed with 9k on the car.
WHEELS: 8/10 couple curb marks
TIRESCONDITION: It will need tires
Exterior
Ø Seibon Carbon Fiber Trunk Clear
Ø RalliArt One Piece Carbon Fiber Spoiler
Ø Custom Painted Carbon Fiber Eyebrows
Ø Full 4 Piece INGS Body Kit ($2,500.00)
Ø Custom Paint – Mitsubishi Cool Silver Metallic with one ounce more
metallic and 5 coats of clear and a two tone rear bumper
Ø 19 “ 2 Piece Racing Heart Pro 5 Rims
235/35R19 Yokohama S-Drive Tires
Ø FIC 1050cc inejectors
Ø JIC Magic Turbo Manifold
Ø EPM o2 housing with a dump pipe
Ø 3” Megan Racing Downpipe
Ø 3” Megan Racing Resonated test pipe
Ø 3” Straight pipe Catback Exhaust
Ø Injen Cold Air Intake
Ø Injen Upper & Lower Intercooler piping
Ø Turbo XS RFL Blow Off Valve
Ø AMS Front Mount Intercooler
Ø Koyo Race Radiator
Ø AEM Tru-Boost Boost controller Running 23 PSI
Ø AEM UEGO Wide Band o2
Ø Walbro 255 fuel pump
Ø Custom Built Nitrous Oxide Intercooler
Sprayer Set Up With Side Exit Purge Valves
Ø Mars Racing 20 Way adjustable Coil over Kit With Upper Pillow Ball Mounts
Ø Greddy Turbo Timer
Interior
Ø Custom Painted Color matched Silver Accents
Ø Steering Wheel Gauge Pod Mount
Ø Custom Build Glove Box Plate Wrapped in Black Leather With A Custom
Aluminum Bezel
Ø Custom Build Trunk Set Up Wrapped In Black and Silver Two Tone
Leather , With a Custom Built Aluminum Cover Plate
Ø Led Accent Lighting
Ø Custom mounted Rear Tweeters Front Tweeters And Component Speakers
Audio
Ø Alpine Head Unit tuned with Imprint (model # coming)
Ø 6” Kicker 602 Component speakers
Ø 4 Kicker custom mounted tweeters & crossovers
Ø Kicker 12” L7 subwoofer & Enclosure
Ø Kicker 750.1 Mono Block Amp
Ø Kicker 350.1 4 Channel Component Amp
Ø Tsunami 1.2 Farad Cap & All Tsunami Wiring
Ø Custom Mounted I pod & Kicker Bass Controller
Ø Optima Red Top Battery
$26,500 or obo
Background:
Thanks for looking,
shows.
Exterior
Interior
Aluminum Bezel
Audio
