LumpyVR4
Supporting Member
- 91
- 49
- May 21, 2014
Sydney,
Australia
Hello all, I'm starting to buy parts for my 2.1 stroker build and thought I'd put the proposed specs up to see if I've picked anything really out of wack for the rest of the combo (I always second guess myself). The car is a VR4 and it's my daily drive, so a good mid range is the most important performance goal.
EVO 8 MAF, large front mount, 2.5" piping, 70mm throttle, stock intake manifold, 1650 FIC injectors.
Stock head (I'll probably debur and polish the ports while the head is off), GSC S1 cams, upgraded springs, Tomei cam gears, ARP head studs, Cometic MLS gasket.
Eagle 94mm crank, ARP main studs, Kiggly girlde, BC sportsman 150mm rods, Manley platinum extreme pistons 8.5:1.
Ported and coated EVO III exhaust manifold, new FP Green, 3" o2 housing into mandrel 3" exhaust.
Intend on running 30psi on E85 and 25psi on 94 pump tuned with ECM link.
