Please Support Kiggly Racing
Please Support STM Tuned
1G 1g 60mm throttle body help
DSM_GSX01
985
13
Jul 27, 2011
La Junta, Colorado
Couple of questions i dont know to well. I have 1g 60mm n/t throttle body. My questions are the by pass plate i can get that dont block all FIAV off will this still help with starting in cold.
Other question is were can i get a rebiuld kit for this body? Haven't found it? Also were is a good place to get a block off plate for n/t ? I have been looking but everything is 1g turbo or 2g non turbo or 2g turbo? Help will be great. Thanks
The 1g non-turbo and turbo throttle bodies are exactly the same, with 1 exception, the turbo has an elbow that connects to the intercooler piping, the non-turbo has a pipe-outlet instead. So you can buy a "turbo" fiav block-off plate, or take your chance doing this:
http://www.dsmtuners.com/threads/free-fiav-block.391977/
Most people will try to turn the black thing in there, just to break the plastic on it. If you're lucky, it'll turn and you can close it all the way, hence the free block off.
The block off plates are the same for the 2g turbo and 1g turbo and NT. There are 2 types of block off plates, ones that block just the fiav and ones that block the fiav and isc. You can use a turbo rebuild kit for the 1g NT TB.
Ok so i can get this kit. 381037021209. Just put it in google search bar.
And i did a heater deleate on my 2g but using this throttle body and i read i would be better getting a by pass then a whole block off?
Heres my throttle body.
That kit would work except that inner gasket is for a 2g TB not a 1g and you don't need an outer TB gasket since the NT TB doesn't use an elbow. You could get everything you need separately form one of the vendors like STM. You need: turbo shaft seals biss screw , biss screw o-ring, FIAV seal, and a 1g TB to intake gasket.
You don't want to do the whole block off plate then you would not have an ISC and your ECU wouldn't be able to control the IDLE.
