Please Support ExtremePSI
Sold 1998 GST Spyder
AZGSTGSX
44
12
Jan 27, 2017
Phoenix, Arizona
Real Garret Big T28 turbo, Brian Crower 272 cams, OBX adjustable cam gears, Pace Setter Tubular manifold, 3" turbo back exhaust, no cat, EVO 560cc injectors, Walbro 255HP fuel pump, Braided steel fuel line, fuel lab inline fuel filter, fuel rail, and fuel pressure regulator,coil on plug setup, ARP head studs, head gasket replaced, timing belt, water pump, starter replaced, Avid black billet racing motor mounts, 3 pod gauge pillar, boost, oil, wideband, Hallman pro boost controller, 1g throttle body, EPROM ECU, ECMLink V3, turbo timer, hard intercooler pipes, greddy BOV, lightened flywheel, dual face clutch, aluminum radiator, injen intake pipe and filter, strut bar, powder coated engine parts, red top optima battery, indigo gauges, EGR block off, stainless steel brake lines, D2 coilovers, camber kits front and rear, Tuned by Wingz performance, transmission shifts perfect, tires have good tread left, everything works, a/c ice cold, clean title just passed emissions, tags good until SEPT2019, I have book of receipts and maintenance records. This is a tuned, reliable daily driver runnning 15-16PSI, can be tuned for more boost/power. Body in good condition, front fenders and hood have chipped paint and clear coat fade, driver seat has small tear. 124,000 miles.
Located in Phoenix, Arizona. Priced to sell asking $4250 firm
