Please Support STM Tuned
1996 Eagle Talon TSi $2200 (amazing shape, runs perfect)
Turbotech
Dec 17, 2013
benbrook, Texas
The car up for sale is a ASE L1 Mitsubishi certified tech owned 96 eagle talon. The car has really been done right and taken care of above and beyond. The paint and interior are as good as you will find and its one of the most mechanically sound dsm you will find. The car has a lot of new parts that are all OEM Mitsubishi parts. The car just got a fully built head last month including new oil pump, new water pump, balance shaft belt, timing belt, tensioner and pulleys, new hoses, new battery, new throttle body shaft seals, cometic head gasket with arp studs. The car has a BIG 16g MHI turbo with tubular O2 housing, Megan Racing 3" downpipe, Megan Racing 3" catback exhaust, Dejon Tool intercooler hard pipe with 1g Blow Off valve, With a Manual Boost Controller set to 14 psi, Walbro 190lph fuel pump, Flashable ECU from a 99. The car has a build Automatic Transmission with a 3800 stall converter from IPT with a trans lab shift kit. The auto is alot faster than the manual due to being able to build boost off the line and it holds full boost between shifts. The car is a FWD but has a quife LSD setup in it. Im sure im forgetting some things.
96 Eagle Talon TSi Turbo (extremely clean, tech owned)
817 812 4205 Randy
