Please Support Morrison Fabrications
For Sale 1995 Eclipse GST
rickygst
May 8, 2014
atlanta, Georgia
https://atlanta.craigslist.org/nat/cto/6122084288.html
My 1995 one owner Mitsub Eclipse GST great project car or track car. Body in good shape but need paint
Motor - 1st G swap, built with Evo pistons, built head, including cams, T retainer, upgraded valve springs, supertec valves, super 20g turbo, custom intake, etc. Lightweight flywheel, FIC 850 injectors, rewire fuel pump, Walboro 255 pump, full 3 inch exhaust with cat, engine approximately 55,000 miles since rebuild, head approximately 6,000. Engine runs strong and no problems that I'm aware of
Parts in Head:
Ferrea Exhaust Valve Seals:
Ferrea Intake Valve Seals
Topline Revised Lifters:
Ferrea 6000 Series Stock Size Valves
Ferrea Manganese Bronze Intake Valve Guides (Standard Size)
Ferrea Super Copper Alloy Exhaust Valve Guides
Crower Valve Spring & TI Retainers : Mitsubishi Eclipse
Valve Locks:
Coilover suspension (ground control kit with Koni Yellow), EVO Brembo brakes all four corners, Braided brake lines, Limited slip diff, lightweight drag wheels,
ECU ECMlink, currently running speed density, Electronic boost controller,
Issues: transmission is making noise and will jump out of first and fifth on deceleration, A/C not working, airbag light is on may just need to go to the dealer to have reset, need paint, need driver side seat repair, was going to replace with racing seats,
There are many other parts but you get the picture.
Contact me 678-five nine one- six eight two three
