Please Support ExtremePSI
For Sale 1993 Eclipse GSX
98yctuner
113
Oct 17, 2010
Yuba City, California
1993 Mitsubishi Eclipse GSX
5-speed AWD manual transmission
131k miles
Clean title
sunroof
6-bolt motor
-no check engine light
-timing belt just replaced
-fresh tune up(spark plugs,oil change)
4 bolt rear end(B1H LSD)
-just recently replaced rear end fluid with redline shockproof gear oil
rebuilt transmission with paperwork
-newer clutch with less than 2k miles
-just replaced transmission and transfercase fluid with redline MTL gear oil
-SS clutch line
-new clutch master cylinder and slave cylinder
Mods:
Ecmlink V3
Speed density
-4bar map sensor and GM IAT
750cc injectors
Walbaro 255 fuel pump
-stm rewire kit used to install
Aeromotive fuel pressure regulator
Forced Performance exhaust manifold
Genuine 16g turbo with ported housing and flap delete
Punishment Racing recirculated 02 housing with vband wastegate
-38mm Tial MVS v-band wastegate
-wastegate spring set for 12psi
3inch turbo back exhaust with stock style muffler tip
carbon fiber boost gauge
ETS intercooler
vrsf piping (short route)
-all t-clamps
-Forge atmospheric bov
rebuilt throttle body with all new seals
Forced Performance intake
Evo 9 rims
Eibach springs with KYB shocks all around
2gb GSX front brakes
Polyurethane motor mounts all around
Optima yellow top battery
Bads:
clear coat is coming off on hood and a bit on the fenders also
Rear end has a whine at around highway speeds
needs an alignment(recently replaced tie rods)
No trades. If interested text or call me at 530-788-four-four-32
