Please Support ExtremePSI
Sold 1991 Mitsubishi Eclipse GSX 2500$
4g63ej257
3
Feb 3, 2014
Mays Landing, New_Jersey
Hello I'm selling a built 1991 Mitsubishi Eclipse GSX has a built engine rebuilt trans with welded Center diff. (call me for more information (609)377-2406
Gt35r Turbo Tial 38mm wastgate (10psi) set boost
Stock 450 injectors (stock)eprom ecu
255lph fuel pump
-6an fittings
Aeromotive adjustable fuel pressure regulator
Ets 3.5 race Intercooler
3" down pipe
3" exhaust
FP o2 housing
Sony CD player Sony door speakers and Sony rear deck speakers.
battery relocation to the rear
ACT2100 6 puck clutch fidanza aluminum flywheel
Autometer boost pressure gauge
rebuilt head new guides new valve seals 3 angle valve job Wiseco piston Eagle rods ACL Tri metal bearings for Rod and mains ARP main bolts balance shaft delete ACL new oil pump cometic head gasket ARP head studs no leaks very clean car absolutely (no rust ) at all runs great!
Clean title, 5 speed manual, all-wheel-drive.
No ps and no ac just recently broke cam gear bolt on start up not sure why and develop a oil leak . Need car gone asap
