1G Whos running the s90 throttle body?
SasaniFab
2,433
782
Dec 1, 2013
Mexico, Connecticut
So ive had terrible luck with these throttle bodies in the past. Im considering upgrading to the jmf billet manifold. They recommend at least a 74mm throttle body. We dont have to many good options for quality throttle bodies that dont leak. Both of my previous 70mm tbs leaked terribly. I switched back to stock and never looked back. Anyone have good luck
I use the actual Ford Mustang tps, you can get it super close to the Dsm one and I was able to run it even on a stock ecu, Idle control I use an external isc that I made from the Nissan purge solenoid with the Dsm isc motor windings so that it will plug in. Keep in mind that I use a Magnus V3 manifold that is already setup for the Mustang bolt pattern, so I use the 100mm Accufab because I cant find a reason to choke off the manifold with an adapter with a turbo this big, however Magnus makes a Dsm to Mustang adapter for that manifold that you should be able to reverse?
https://accufabracing.com/throttle-bodies
https://accufabracing.com/throttle-bodies/racing-throttle-bodies/race-90-throttle-bodies
http://magnusmotorsports.com/product/magnus-remote-mount-iac-adaptor-for-mitsubishi-dsm-evo/ wouldn't this work? also do you have a link for the tps sensor or part number
Yeah, the Magnus part would work just fine, its just a more expensive solution, but its a nice piece, I didnt feel like paying shipping from Canada and no one had them in stock in the area that I know of or I would have grabbed one.
https://www.rockauto.com/en/moreinfo.php?pk=10064636&cc=1133985&jsn=619
I have successfully implemented a true 74MM S90 throttle body, I had to work over each side of the throttle shaft to keep it from leaking but after a lot of effort and time I was able to do so.
I did also by upgrading the shaft seals. Why cant these peopls upgrade their shaft seals. Their like 10 bucks. Im not buying a new product to repair it
Kiggly had a stock throttle body to a SMIM ( stalk his gallery) and twicks69 (IF profile is current) is running a 1G TB to SMIM
Nuff said
PS, you can always run the adapter plate back to stock TB if you get that SMIM
