Twiggy built
- 1
- Aug 20, 2018
Halifax,
NS_Canada
I recently just replaced my clutch master, slave cylinder, and installed a ss clutch line to try and narrow down a problem i was having with my clutch slipping. Ended up being the clutch itself so fast forward installed a xtd Stage 2 Clutch got it all put together the other day and went to take it for a test drive and the clutch is now engaging on the floor. I have the force the clutch onto the floor super hard other wise i can’t shift into any gears without grinding accuring. I’ve made sure the clutch is bleed and also i have tried adjusting the master. Any help on what might be wrong? I got a new clutch pedal assembly that I’m also going to try and swap into the car to see if that might help or change anything at all
