2G Cant Find Bumper Part
Millerman02
Aug 27, 2018
findlay, Ohio
Ill give you all a back story to why I need this piece. I just bought a 1998 Mitsubishi Eclipse (rs model) and it needed a good bit of work. I had to do body work to the fenders and that involved removing my bumper (or so i thought it did). basically i got the fenders done and put back on but there was a piece that was so rusted that i just pulled it out of the bumper. If i wouldnt have taken this out it would have fallen off while driving. it is a metal bar that is on the inside of the bumper cover. Is on the bottom of the bumper cover but on the inside. I need this because the bumper has been bouncing all over the place when i drive. My only problem is im not sure what i should be trying to find. If anybody can help that would be greatly appreciated :pray:
I believe the part you are looking for is MB914136, should be around $20-30 if its still available. Can always try the junkyard as well.
They're still available new... But a lot more than 20 to 30 bucks. They range from 95-125 dollars and you will be hard pressed to find one at a junkyard that is in a single piece. Every trip I've taken to my local u pull yard I've looked for one as mine was bent and doesn't sit right anymore, I've yet to find one.
