For Sale Parting out a '96 Dodge Avenger
nbgorman
Jun 18, 2013
Near Lima, Ohio
Unfortunately the day has come. After 3 very good years and 40,000 miles on the new motor, suspension and steering components have begun to fail faster and faster. I have many performance parts which I would much rather sell to some of you amazing folks than straight to the scrap yard. Parts up for sale include but are not limited to:
[Current mods for sale]
Crower stage 2 cams - $250 OBO
Ported and polished head with crower valve springs+retainers - $400
Bosche Ford Racing fuel injectors - $75
Fidanza adjustable cam sprockets - $50
CRACKED DC Sport 4-2-1 header - $50
EGR delete plates - $25
Custom crankshaft scraper + windage tray + baffles - $300
Custom cold air intake - $100
~45 mil throttle body - $50
Prothane motor mounts - $100
NOTE: Buyer pays shipping
I am at work currently so I do not have any pictures of the parts, though I will start yanking parts out and getting pictures posted up. If any of you have questions about parts for sale or would like something please let me know!
Original build post -> http://aseclub.net/forums/index.php?/topic/129738-1996-avenger-420a-and-5-speed/
List of interchangeable parts between 2nd gen Eclipse and Avenger
Front Knuckle, Front Lower Lateral Control Arms (straight), Front Curved Control Arms (curved), Front Sway Bar End Links, Front Sway Bar, Front Upper Control Arms, Front Coil Spring, Front Struts (between 4 cyl cars),Rear Sway Bar, Rear Trailing Arms, Rear Upper Control Arms, Rear Lower Control Arms, Rear Toe Links, Rear Coil Spring, Coil Spring Insulator, Rear Coil Spring Seat, Rear Shocks, Outer Tie Rods, Inner Tie Rods, Front Wheel Bearing Assembly, Rear Wheel Bearing Assembly, Rack & Pinion Set Up, P/S High Pressure Hose, P/S Return Hose, Front Calipers, Front Caliper Mounting Brackets, Front Rotors, Front Brake Pads, Master Cylinder, Front Brake Lines (Hydraulic), Rear Brake Lines (Hydraulic) Drum & Disc, Rear Calipers, Rear Caliper Brackets,Rear Brake Drums,Rear Brake Pads,Rear Brake Shoes, Rear Rotors, Hood Latch, Radiator (4 cyl only), Radiator Cap (4 cyl only), Fans, P/S Reservoir, Coolant Overflow, Coolant Overflow Bracket, Battery Tray & Hold-down Hardware, Firewall Relays, Cruise Control Box & Cables, Cruise Control Air Box, Windshield Washer Reservior, Windshield Washer Pump & lines & Sensor, Door Handle,Cowl Panel, Front Wiper Arms/Blades, Door Handle, Door Panels* (while not exactly the same for all years, they do interchange), Power Window Switches, Dash (main section), Glove Box, Dash Cluster Surround Bezel, Steering Wheel, Air Bags, Kick Panels, Door Sills, Center Vent Panel, HVAC Controls, Dash Side Vents (on the ends of the dash), Knee Panel, Dash Corner Panels,Dash Gauge Cluster* (while not exactly the same, MPH on Eclipse goes to 160, it is a direct fit part, Cruise Control Switch & Surround bezel, Power Window Motor, Front Seat Belts, Windshield Wiper Steering Column Stock (may be year sensitive), fuel pump, gas cap, 5 speed Trans, passenger side axle (between 4 cyl cars), Clutch, Clutch Slave Cylinder, Clutch Pedal, Clutch Master Cylinder
