predator hood, help
as long as it is a non turbo, it will fit fine with no modifications. if you have a turbo, the timing belt cover sticks up a bit (hence the bump in the oem hood) and it wont fit without modifications. though, i havnt done it and i dont know people who have, so i dont know what those modifications are.
Originally posted by 1TuffRS
probably just notch the underbody of the hood. It doesnt even fit NTs without them having to move the PCM and the radiator overflow bottle.
Actually it will fit nt without moving anything. I have this hood on my car and it fit very nicely. Bought mine fron Autogear.
see thats what i thought, there are a couple of guys on 2GNT who have the predator hood and they both had to move the pcm and radiator overflow bottle. Is yours aerogear though, cuz I suspected that they ended up with a knock off. Im def going to get that hood in the future
i know for sure the aerogear hood will fir on none turbos . i am notsure about the knock offs
I have a predator hood on my GST....you have to modify under the hood....i still have to do some cuz it scrapes against the timing belt cover.
It will fit 2g turbos, I had to take my TB cover off and "modify" my strut towers a bit (pound in) but its well worth it...
The last pic shows the timing belt just rubbing a little bit and the other one is of the AC line that needed room, so I cut a little bit out there...
  • Wanted 6 bolt NT water pipe
    • chrisman287
