jazzyjay
- 216
- 0
- Mar 27, 2003
Yes, yes I know that a 1g head is obviously has bigger ports, but in this case is bigger better. If I accept as fact that the more I port a head the more low-end I lose (correct me if I am wrong). Working with that I mind, I would think that a 2g head will work better suited for a small turbo (a 16g in this case) efficiency range than a 1g head. All other spec of the car will be to factory specs other than the fueling. Is my theory flawed? At what point does a 1g head out shine a 2g?
this has been hashed since the beginning of time...I am all about port velocity vs. port volume, Injectors aiming at intake valves vs port floors.
