580cc injectors Need Help????
95gsx6bolt
Aug 26, 2005
Carmel, Indiana
Okay,
I dropped off my car to Buschur racing, and they told me that I didn't need 580 cc injectors installed, so they'll tune it and dyno it. Why? I thought, I would need them?
This is my set up:
6Bolt Motor in a 95 GSX
Greddy Upgraded intercooler
K&N Filter Kit
Super 16 G
Apex S-AFC II
3inch downpipe all the way back
Walbro 255 fuel pump
And they also told me that I didn't need a SX AFPR also?
What is going to happen if I still have stock injectors???
And why did they tell me this???
Could someone help me out?
These guys are one of the best in the business, but why did they recommend this to me?
95gsx6bolt said:
Okay,
This is my set up:
K&N Filter Kit
Super 16 G
Apex S-AFC II
If you are running stock injectors and want high performance from your 16g, upgrade them. Also, if you are running a 255 pump it is wise to get a FPR. Is it possible to get the car running and tuned with the stock injectors? Yes, but you will be nowhere near the potential of the 16g. Are you sure you understood everything they said about the injectors? Not flaming you nor Buschur of course. Just asking if this is exactly what they said.
They just said, I didn't need them and that it'd be too much fuel coming from the 580cc's. Cause they have it with them when I dropped it off. Should I go ahead and tell them to put them in and retune it?
Will I not be able to boost to a certain level with stock injectors?
Jon is correct. The most you would want to run a 16G on stock injectors would be roughly 15 psi. With upgraded injectors, you would be able to push the 16G well beyond 15 psi. The size of injectors that you would need would depend on your goals with your set-up.
That is a question you should have asked them on the spot.
I guess the main concern is, just breaking into high 12's even 12.99's
Will I be able to do it with this setup and with stock injectors?
How much horses to the wheel do I need to hit high 12's?
Thanks,
Te
