2G Identifing EPROM ECU
Go open that fugga up. Theres a tutorial on how to remove the ecu in you car on www.vfaq.com :thumb:
It will show you a pic with a non eprom and eprom ecu so you can tell.
Edit: crap I just noticed you said 95, I think all 95s are eprom right? :confused:
Not all. I've come across a few that are not EPROM. Like he said, you have to open up the case and look inside.
And once i open it up, how can i tell?
Also within installing a 95 EPROM ECU on my 97 GS-t will their be any problems i will run into or will it work fine?
2G ECU - EPROM Check
To check for an EPROM inside your 2G ECU, pull the ECU out and check the sticker on top. The sticker should have a part number on it (e.g., MD309947) with some other numbers and a letter in the lower right hand corner. The image below shows this sticker.
If the letter in the lower right hand corner is an "E", then the ECU most likely has an EPROM. To know for sure, you can follow the same steps as outlined below for the 1G ECU.
A list of valid 2G turbo ECU part numbers follow.
MD312464* MD309947* MD321911 MD321912 MD326328
MD335287 MD346675 MD346676 MD359402 MD359403
The two w/ stars are MOST likely eproms, not guarenteed.
This info should help you out tremendously.
Real good to know since we are starting to move on to turbo after the 93 and 96 are sold.TY,it is very informative.
Julia :talon:
Quasimondo said:
Nope, it'll run fine.
Not true. You must swap out the #1 and 4, and #2 and 3 plug wires or it won't fire right. See, 95's have a different firing order than any other year of DSM's. And funny, the 95 eprom is the only one you can use in upper model 2g's, so swapping the plug wires are a must.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
