v8s_are_slow
- 2,824
- 280
- Sep 30, 2002
Panama City,
Florida
Back in the old days (around 1997), I didn't hear much talking about things like "x" a/r, garret, hybrid, mitsu, ball bearings, etc. It use to be people just upgarding to 14b's, 16g's, 20g's, etc. Now there so much talk about this and that that I've had a hard time following. Mainly because I've only had one type of turbo for so long. And lately, I've just searched threads to see what people go with as far as a turbo for "x" setup and try to see what works best for them (as I'm sure many others do). But screw all that. I wanna be educated and know for myself.
Can you guys with the turbo knowledge please break down some of the terms and help me (and others) decipher some of what I need to know?
Things such as the difference between a mitsu, garret, etc.
Meanings of .63, . 70 a/r, etc.
Reason you'd want or NOT want to port the turbine inlet or outlet? Or both?
Can someone tell me what a 67 mm inducer is? Or any other size?
What's the difference between a 50, 60 trim, etc.?
What's a 360 degree center thrust bearing?
And so much more I'm not even listing.
When looking at a website such as Slowboy, some of the turbo's have different options and I have no clue why I'd wanna get this or that, and maybe not something else.
There's so much out there I don't know where to begin? And when discussing turbo's, I see so many people bickering that it makes it hard for me to be able to decide for myself. Hoping many of you turbo wisemen can help out and post your knowledge. Thank you!
Scott
Scott
, but to keep this primer concentrated and to the point as possible I wont go into details on every manufactures entire product line. But for a quick example, Greddy (Trust) contracts Mitsubishi to make generic (T78, T88) turbochargers for its own line of proprietary turbochargers for the aftermarket.
. That is where Robert Young (then a turbo rebuilder for Turbochargers.com, now owner of Forced Performance) came up with the idea to put the more diverse Garrett line of TO4E compressor wheels in the Mitsu housings with minor modifications. When used in conjunction with the larger TDO6 and 6h turbine wheels found in the FUSO truck apps, these Garrett compressor wheels opened new doors for DSM aftermarket performance. This new line of turbos was deemed the Frank series of turbos. Several combinations of turbos where standardized as Frank 1, 2, 3, 4, 5 and later 6. Each Frank turbo combination had its pros and cons (some more than others). It was then thought to simplify the series into one smaller more responsive turbo for mostly street use (Green) and one larger street/strip turbo that could really dish out the horsepower (Red). There have since been other variants on the hybrid idea by several different companies. Now some of the more popular ideas on the hybrid idea involve casting a new turbine housing that bolts a complete Garrett CHRA (cartridge) into a housing that bolts right up to the DSM 60mm round flange manifold. For example, the FP30 series of turbos have a custom-cast 304SS racing volute housing that plugs the latest generation of Garrett Ballistics Concepts GT Ball-Bearing turbos that bolt right to a ported EVO or 2nd gen manifold.
i just thought i'd mention it in short.
