gixrman
- 1,997
- 18
- Nov 13, 2002
Frederick,
Maryland
Anyone know were it is? Everyone that I've seen ( or someone says that it is) is the big 16g which is not the same.
DSMSpyder99 said:OK the second link says TD05HR-16G6 which is the offical name of EVO8 turbos that is not a EVO 3 TD05H-16G
DSMSpyder99 said:so who cares if the wheel is the same. The EVO 8 is a REVERSE TWIN SCROLL and has a 10.5CM^2 HOUSING. With twin scroll you get better boost response and with a 10.5cm^2 housing you can bet ur ass you get alot more topend. Just use common sense people run 24+PSI on EVO8 16G on pumpgas. You cant push a EVO3 16G that high it will just blow hot air and will fail after a short period of time if you run on pump gas. So saying that the EVO3 and EVO8 have similar compression maps is just wrong.
guitarXgeek said:The compressor map displays the compressor wheel effeciency, not considering turbine housing size, etc. Both turbos use the same wheel, therefore their compressor maps will be very similar if not the exact same.
Mike000 said:
ShapeGSX said:Why do you care about CFM? Mass airflow is a much better measure. CFM in a vacuum will be infinite. Figure that one out.
gixrman said:I called slowboy yesterday(they sold me my evo16) and asked if they had a compressor map for the turbo and they stated that Mitsu does'nt release comp. maps to the public. :thumbdown
Does this show the small 16G wheel as more efficient than the big16g? If you look at airflow on bottom (.25) at a pressure ratio of 2.2 the small is over 74% efficient while the big is between 60 and 65%? Am I reading this right?guitarXgeek said:Well here's a website that lists just about all of the popular Mitsu turbos (evo3b16g is not included, though)... http://not2fast.wryday.com/turbo/maps/
Talonman said:Does this show the small 16G wheel as more efficient than the big16g? If you look at airflow on bottom (.25) at a pressure ratio of 2.2 the small is over 74% efficient while the big is between 60 and 65%? Am I reading this right?
