DSM Curb Weight FAQ/breakdown
Sotarts
1,953
24
Sep 30, 2002
Chicago, Illinois
A/C:
Full System, 90 TSi AWD: 35lbs
Full System, 99 GSX: 42lbs
Cooling System:
1G Stock metal radiator fan: 6lbs
1G Stock plastic radiator fan: 5lbs
Carpeting, sound deadening material, etc:
Sound Deadening Material Inside Car: 25lbs
Spare tire cover + privacy cover: 20lbs
1G rug in rear hatch: 2.5lbs
Each floor mat: 3lbs
Tools, etc:
Spare Tire and Jack: 35lbs
1G Stock tool bag and tools: 2lbs
Under hood, hood itself:
Hood, 1G Hood: 44lbs
Hood, 2G Hood: 42lbs
LS1 MAF With MAF Ends: 1.5lbs
Charcoal Canister, 90 DSM Turbo: 3lbs
Fog Lights: 5lbs
Stock 2G battery: 42lbs
Oddessy Battery: 14lbs
Crankshaft: 6 bolt stock crank 35.5lbs
Cruise Control: 90 DSM Turbo With brackets and bolts and lines 6lbs
Various Brackets: Firewall brackets, Intake, air can, heat shields etc 10lbs
1G rubber intake with BOV return hose (from turbo to MAS): 3lbs
1G starter: 8lbs
1G Intake Manifold, With EGR Block off plate: 10.5lbs
1G intake manifold with ALL sensors/ICS motor + support bracket + throttle body: 23 lbs
Drivetrain
1G AWD Transmission, Complete: 125lbs
1G FWD Transmission: 85lbs
DSM 7 Bolt Flywhee, unlightened: 19lbs
DSM 7 Bolt Flywheel, lightened: 14lbs
ACT 2600 Clutch Disc: 3lbs
ACT 2600 Pressure Plate: 10.5lbs
Exhaust/turbo related:
APEXi N1 Silencer: 0.5lbs
Tial 40mm wastegate, With Metal o-ring: 1.5lbs
2G AWD Catback, No muffler: 17.5lbs
2G AWD Catback, Full Catback with Muffler: 37lbs
2G AWD Muffler 19.5lbs
16G turbine housing, ported (made few years back or less time ago): 9lbs
1G 14b original turbine housing, unported: 11 lbs
Evo III exhaust manifold, ported: 12 lbs
Evo III o2 housing, unported: 6.5lbs
1G original o2 housing, unported: 6lbs
1G original exhaust manifold, unported: 10lbs
14b turbo, only center cartridge with wheels+comp. housing, no turbine housing: 5.5 lbs
Seats, safety belts, etc:
1G OEM Front fabric seat plus slider and belt buckle. No belts: 50lbs
1G OEM Front Seat Belt Assembly: 30lbs
1G OEM Rear Seat Belt Assemblies, Speakers and mounting plates: 18lbs
1G OEM Rear Seats (upper and lower, leather): 40lbs
1G OEM Drivers Seat (Leather Adj lumbar): 50lbs
1G OEM Rear seat bottom: 12lbs
1G OEM Split rear seat back: 18lbs
2g OEM seat, cloth, no power: 43lbs
1G middle rear seatbelt mount: 2.5lbs
Suspension/wheels/steering:
1G Stock Shocks, each: 12lbs
1G AWD KYB AGX rear struts, each: 5lbs
1G KYB AGX front struts, each: 8.5lbs
1G Stock Springs. each: 6lbs
5-spoke wheel, 1996 GS: 20lbs
95-96 Talon Swirl Rims, With 205-55-16 tire: about 42lbs
97 GSX wheels, 17x6.5, no tires, each: 25lbs
90 Laser stock 16" steel wheels w/very bald Sumitomo Srixon-4, 205/55 tires: 45lbs
90 Talon stock 16" aluminum swirl wheels w/70% tread, Goodyear Eagle RS-A 205/55 tires: 42lbs
Electrical, sound, etc:
Stock Radio/CD Player/Amp: 10lbs
DSM Turbo ECU 1.5lbs
Exterior:
1G Bumper, Stock Metal Bumper Rear 32lbs
1G Bumper, Stock Bumper Front 35lbs
1G License Plate w/bracket: 2lbs
Tail light ('90-'91 Talon): 2 lbs
Rear center piece ('90-'91 Talon): 2 lbs
1G ('90-'91) clear pass/flash-through front headlight trim, with bulb and socket: 1.5 lb
1G ('90-'91) corner/side marker, with bulbs and sockets: under 1.5 lb
Interior:
Center storage compartment door: 2 lb
Center console one-piece that surrounds the shiftter: 2 lb
Passenger side dash storage compartment door: 2+ lb
Metal brackets that hold up the wood in rear hatch: 2.5lbs
Misc:
Rear Wiper Assembly: 5lbs
Sunroof, Entire 2G glass sunroof assembly w/screws + brackets: 32lbs
1G Hatch, with glass + center spoiler piece + wiper motor + brackets - COMPLETE: 60lbs
(someone needs to start making these out of CF or FB with glass substitute :D )
My '90 AWD Talon, with 1-2 gallons of gas, all fluids full + 15-20 lbs of crap in the car, no driver: 3180 lbs :cool:
For search purposes:
weight
weigh
weighs
weighed
weighed
weighing
lbs
lb
Some item weights might be useless to know, interesting nevertheless. Some people might be forever bothered to insanity by not knowing the weight of a specific part, this thread should be the one to help you!
A few other threads discussing weights and weight reduction:
http://www.dsmtuners.com/forums/showthread.php?t=126446
http://www.dsmtuners.com/forums/showthread.php?t=103051
http://www.dsmtuners.com/forums/showthread.php?t=124485
http://www.dsmtuners.com/forums/showthread.php?t=124017
http://www.dsmtuners.com/forums/showthread.php?t=51000
Please feel free to add other appropriate threads discussing weights.
Also add weights of other stock and aftermarket parts you happen to come across or even decided to weigh them yourself; things like pistons, rods, your aftermarket wheels, etc... I'm sure someone will appreciate your contribution now or later. :thumb:
I can Honestly say that I felt a difference when I took out my leather seats including my reasrs. And put in Sparco Speeds. ANd also removed all my tire crap including the jack. Plus my seat belts Was not huge, but I felt it.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
