1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Street Build Work in progress
Year:
1991
Model/Trim:
Mitsubishi Eclipse GSX
  • Ownership Status:
    I own it
    Turbo Type:
    GT35 Variant
    Drivetrain:
    AWD
    Transmission Type:
    Build Type:
    • Street
    Mods-Bolt-on:
    BW S256ETT/bullseye, FP cast manifold, Chinese wastegate :(, XS power 4in FMIC,GFB bov,Brian crower cam gears, Gates timing belt,FIC 1000cc,BSM oil cooler/catch can, mishimoto radiator/duel fans, taylor 409 plug wires, full 3in turbo back, electric exhaust cutout, 450lph walbro rewired, fuel lab FPR 40psi,6an line
    Mods-Engine:
    Micropolished crank,Forged rods, ceramic coated pistons, full ARP, balanced, +.5mm stainless valves, titanium retainers, dual springs, delta 276s, port n polish/gasket matched,balance shaft delete
    Mods-EMS & Logging:
    Dsm link V3, speed density, gm 4 bar,turbo smart 2 stage EBC 28psi/32psi, wideband/boost/oil on a pillar
    Mods-Drivetrain:
    Act 2600 kit, lw flywheel,short shift,Symorski kit,avid racing aluminum motor/trans mounts
    Mods-Handling:
    Tein springs, Kyb struts, Megan front rear strut bar, ebc drilled slotted rotars, green pads
    Parts Wishlist:
    English racing dyno tune
    Half cage
    70mm Throttle body
    Jmf manifold
    Enkie RPF1’s
    Built trans
    Respray car
    Background:
    Shooting for a 11 second street car on street tires
Share this Item
User Comments
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
